wet floor
Old Apr 15, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
wet floor
ok the pass side of my car is soaked.. we have been having 40+days and nights of endless rains and now its starting to stop finally.. anyways could the leak be from the floor itself.. i have a double xbrace and 2 of the mounting points is right under the floorbaord but i see no cracks from there... any ideas where it could be from
Old Apr 15, 2006
R1Style's Avatar
Check the seals around your window, door, and windshield.
Old Apr 15, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Check the seals around everything on the passenger side. Was anything drilled around the area? Also what about grommets, have you run anything through the firewall and maybe one got dislodged?
Old Apr 15, 2006
DDragon7's Avatar
You could also take a hose and try to find the spot that leaks by spraying all over the spots you think it might be leaking slowly, and have someone inside the car to tell you when it gets wet.
Old Apr 15, 2006
Super Member
err.. my foglight harness.. i belive the grommet didnt fit well
mistahlorax13
21
Nov 18, 2015 12:47 PM
General DIY
Sep 25, 2015 08:02 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
NROD315
Sep 12, 2015 02:46 PM
