Steering wheel not returning to middle?
Old Mar 20, 2006
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
Ok so here's the deal. If I turn my wheel all the way to the right, and then drive (without holding the wheel) the wheel will spin back eventually into its regular middle(straight) position, like it's supposed to. But when I do the same for the left, the wheel will stop spinning like just before it goes to the middle. A better way I can describe it is, if your wheel is straight, and you turn it completely sideways (like you were doing a 90 degree turn) it stops there and I have to manually bring it to the middle. Also if I am stopped and my wheel is straight, when I hit the gas the first thing the wheel does is go in that left position, as if my car things that is center. And for some background info, I ran up a curb pretty hard prior to this. What do I need fixed?
Old Mar 21, 2006
DDragon7's Avatar
You may have a bad aligment, also does your car pull to the left if your going straight(not starting) with your hands off the steering wheel?
Old Mar 21, 2006
karizzle's Avatar
Pinkslip Racer
ya if i let go of my wheel, the steering wheel rolls a bit to the left which = yes my car does pull left. so its alignment?
Old Mar 21, 2006
DDragon7's Avatar
Yup, alignment, plus may have broke something, ask the guys that are gonna do your alignment to check first.
Old Mar 21, 2006
tfnaaf's Avatar
BLDNPSI Mod
You need a new rack and pinion from your description of when you give it gas and the wheel turns on its own. Im guessing the car pulls the same direction that the wheel turns on its own? Its called a power steering imbalance. This hapens usually when a impact to the steering linkage twist the pinion shaft causing the valve to be stuck one way or the other. No real remidie other than replace rack and pinion This doesnt mean that there may not be other problems , but thats one BIG one
Old Mar 22, 2006
karizzle's Avatar
Pinkslip Racer
how much would that cost me to fix? probably my summer tire//rim fund ****!
Old Mar 22, 2006
tfnaaf's Avatar
BLDNPSI Mod
Contact your insurance ccompany! I would guess $500 and up depending on what else may be fvcked up
honda200192
Suspension
Oct 27, 2019 12:23 PM
honda200192
May 31, 2015 05:57 PM
Optimus34
May 25, 2015 11:52 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
