o2 sensor issues
Old Feb 16, 2006
Slammed99Si's Avatar
Slammed99Si is an unknown quantity at this point
o2 sensor issues
I just threw my stock cat back on (a brand new one) because those cheap resonator cats were not dropping the check engine light. With the correct cat on and my check engine light still on do i need to reset the ECU for it to go off? is the check engine light causing the oil to burn rich or the signal going to the computer?
Old Feb 16, 2006
streetglower's Avatar
once the check engine light comes on, it needs to be reset if the problem has been fixed. So either pull the ECU fuse or disconnect the negative cable on the battery. And there is no such thing as the oil burning rich.
Old Feb 17, 2006
Done
Done
Well it stayed off for about 5 hours
and the light came back on - when I was coming to work today - When I put the new universal honda sensor on one of the colors did not match. I was worried about that. It was a denso sensor...you think because I have an SI I can't use a univeral sensor? I thought those things were all really similar...
Old Feb 17, 2006
go buy the 02 sensor that is made for your year and model.
juror
May 26, 2015 06:35 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
Blaster30
Apr 22, 2015 12:21 PM
wh3nw0rdsesc4pe
Mar 23, 2003 09:57 AM
