car is not doing well...
Old Jan 28, 2006
  #31
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
gearbox, i think in the end you just need a get a new car. That's just my two cents.
Old Jan 28, 2006
  #32
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
wtf is a cell light? god im so happy my civics up for sale.....
Old Jan 28, 2006
  #33
streetglower's Avatar
its your check engine light. CEL= check engine light.
why? there is nothing wrong with his car. A simple sensor failed.
Old Jan 28, 2006
  #34
i've noticed alot of people selling their cars due to problems which is too bad. i guess 3-4 years is the lifespan for these cars. I am really wishing I picked up a used civic instead. 01+ = pos
Old Jan 28, 2006
  #35
dru106's Avatar
ThE CoRRupToR
Yes, this is really weird!!! Right after my tranny went out other ppls cars starts to fvck up. I've really lost a lot of time and $$ on this car just to have nothing but problems. I said it before and ill say it again..............01+ civic = POS!!
Old Jan 28, 2006
  #36
you know my old 87 jetta had its share of problems, but tranny wasn't one of em. that auto lasted more than 10 years prolly on the same tranny fluid even cause i don't think anyone ever changed it. shifted like normal all the time.
Old Jan 29, 2006
  #37
dragman99's Avatar
dragman99 is an unknown quantity at this point
Originally Posted by gearbox
ya ideally. the tps is held with some weird screw/rivets that can't be taken off. otherwise i would've played with it and set the proper voltage. the problem with the bore is the idle adjust screw doesn't work anymore. the lever just sits against the tb. so it wouldn't have helped trying.
all you've gotta do is take a die grinder with a cut off wheel on it, and lightly cut slits in the rivets, and then turn them out with a flat blade screwdriver. then you can adjust your tps to the correct setting which is 0.50v at idle.
Old Feb 23, 2006
  #38
brandonhhh's Avatar
brandonhhh is an unknown quantity at this point
what is tps?
Old Feb 23, 2006
  #39
TPS is throttle position sensor. on your throttle body is a sensor used to tell the ECM the throttle position.
Old Feb 24, 2006
  #40
Ricky's Avatar
Ricky is an unknown quantity at this point
how you going shift gear if you have automatic??
Old Feb 24, 2006
  #41
mrDFWmechanic's Avatar
gearbox i would stop messing with your car cause it seems to keep messing up
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
