Help..flickering battery light issue
Old Jan 18, 2006
02CivicDX's Avatar
02CivicDX is an unknown quantity at this point
Battery light flickering issue for about a week. I know its a charging problem from reading some other posts.
Had 2 rebuilt alternators put on and its still doing the same thing. Battery was recharged and is holding power. so the battery is not the problem.
Any suggestions of what else might be causing this.? Could there be something wrong with the ECU or other wiring/electrical?
Also had some stereo grounding problems before all this stated happening but the stereo is re-grounded.
Old Jan 18, 2006
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Could be a grounding issue not with the stereo but with the wiring in general or could be something not even close who knows on that one
Old Jan 19, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Check all the chassis grounds FIRST. It's a known issue that some can get loose. This screws up the whole electrical system.
Old Jan 19, 2006
yeah the set behind the passenger front tire let loose on me awhile back but mine was way worse than a flickering battery light.......I believe there are about 6 or 7 grounds there all on the same bolt.
Old Jan 20, 2006
Karumba's Avatar
Boredom causes changes ;)
Since I had a bad experience with my garage, check to ensure that the alternator was installed properly. If it is, then check the grounds as stated above.
Old Jan 23, 2006
02CivicDX's Avatar
All fixed...after a 4th alt. 3 other alt had bad transistors or risitiors...cant remember....but its fixed finally
CarStuff
Dec 6, 2020 12:52 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
tylerginevan
Apr 27, 2015 12:29 PM
SSMatey
Apr 13, 2015 06:09 PM
