New findings to stalling problem.
Old Jul 19, 2002
  #61
2k1SINCE00's Avatar
2k1SINCE00 is an unknown quantity at this point
It is the ECU, seems someone just replaced the wireing harness and its better.
Old Sep 30, 2002
  #62
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
Hey Ronin i had the same problem with my car. It idles fine but sometimes the rpm drops to below 500 and then returns back to 750. Here's what i did to cure the problem:
1. run the engine until it gets to normal oper temp (drive around if you wish) then shut it down.
2. remove the ecu fuse from the fuse box under the hood (it's just below the 7.5 Amp one.i think it's 15 amp. there was a post recently which says to remove the 7.5 fuse, this is wrong).
3.wait for 10 mins and replace the fuse.
4.start the car without touching the acc pedal and let it run for 10 mins.
5.shut off the car and start it again.
6.shut it down again and then restart and go for a ride. That should cure the problem. during the whole process you should not touch the acc pedal.
Old Oct 1, 2002
  #63
Ronin's Avatar
Ronin is an unknown quantity at this point
Thanks for the tip, but I don't have the stalling problem anymore. Seems to have disappeared completely ever since I moved here to San Diego. The other people having this problem should give your solution a try, though.
Old Oct 11, 2002
  #64
Erichyung's Avatar
Erichyung is an unknown quantity at this point
what's acc pedal?
Old Oct 12, 2002
  #65
Ronin's Avatar
acceleration pedal
Old Oct 13, 2002
  #66
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Hi there and the rest of you guys having this "shuttering" problem. Get Honda to replace the ECU. There's a batch of ECUs that are faulty. I had mine replaced and its fine now. I have the exact same symptoms as you guys regardless of whether the aircon is on or off. Replace the ECU !!!! Don't allow them to adjust the tappets. They adjusted mine twice before confirming it was my ECU. Damn it.... I lost the precise engineered tappet clearance from Honda(Japan) because of this !!! The tappets being too tight is total bull.. don't take that excuse from the mechanics at the dealership.. get that darn ECU replaced !!!! Hope you guys get it fixed soon. Good luck. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 19, 2002
  #67
Erichyung's Avatar
so why is the ecu making our cars stall?
Old Oct 20, 2002
  #68
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
what is the idle RPM supposed to be at when the car is in Park(yeah, i have to drive auto cause i wasn't the one who paid for the car..)?
my old 02 LX coupe idled at 1200rpm when i first start the car...it'll drop to around 1000rpm after idling for about a minute and still i Park
i picked up my new 02 SiG yesterday and when i started the car, the RPM only went up to 750ish while the car is in Park(yeah, this one is automatic too cause again, i didn't pay for the car)....
is this difference in RPM normal?
both of my coupes had a date of July 2002 on that door sticker so they were made in the same month...
Old Oct 20, 2002
  #69
MaxPSiLX's Avatar
MaxPSiLX is an unknown quantity at this point
Idle specs are 750 +/- 50 rpms I believe.
Old Oct 20, 2002
  #70
Erichyung's Avatar
i think around 700. You can't get the exact rpm w/the stock meter.
Old May 3, 2003
  #71
Zigen1's Avatar
Zigen1 is an unknown quantity at this point
hi, guys, I have the exact problem with my civic, mine happens more when the engine is still cold and happens less when engine has been running for like 20-30 minutes already. Its good to know that I am not the only one who has this prob on their 2k1, so how did you guys fix it?
Old May 19, 2003
  #72
Pharoh's Avatar
Bobaganoosh!
Hope this helps...I had the same problem with my 2K1 Si (US EX). The car would totally croak when I slowed down..This is really cool when you're turning through an intersection and the engine shuts down taking the power steering with it..Yikes!
Anyhow...here is how the story materializes...
I was ripping down an on-ramp when my VTECH and ECU started battling it out over oil...The oil in the pan shifted so much that the ECU didn't recognize enough to let the VTECH run so it kept shutting it off...It was brutal. Anyway, went in to get the oil changed so as to stop that problem and they asked me if I had ever heard a noise under the hood...I said "umm...No"..They said that that the AC Compressor was going (bearings) and that they removed the belt so it wouldn't catch fire before they could get the new parts....So I'm like..okay that 's cool..I booked another appointment.
The next day I'm driving home on the highway from work in rushhour traffic and the car cuts off 7 times and now the noise is worse than fingernails on a blackboard!!!
I get home to find the damn thing smoking under the hood. In case I need to say this.....The belt was never removed!
So, I bitched and I bitched and I got a 2004 Accord coupe as a rental for three days while mine was in waiting for the parts. Finally got the work done and now we arrive to today....
The car has never cut out but the idle does still drop to about 300 and then pick up but I find it's only after breaking...mostly harder breaking.
Changing the AC Compressor definately stopped the engine from dying but the low idle is still happening from time to time.
Anyway, having said all this I should point out that the dealership I go to (and bought the car from) are very accomadating (aside from the belt issue). They gave me a great car to drive while mine was in and despite all my mods they assume the position of 'Well it wasn't like that when we saw it'...I love those guys.
I find that a dealership with a big supply of aftermarket goodies is usually your best bet..
Cheers All!
Old May 19, 2003
  #73
Ronin's Avatar
Hey, I used to live in Ottawa. Which dealership gave you an Accord as a loaner?
Old May 19, 2003
  #74
Pharoh's Avatar
Bobaganoosh!
Hey Ronin..It was Lallier in Hull...Okay, not quite Ottawa but close enough.
Old Oct 12, 2003
  #75
Samari's Avatar
i just resetted my ECU and it seems to work fine now. I will start it up in the morning to see if it is still cool.
Old Oct 14, 2003
  #76
Samari's Avatar
nevermind, resetting the ecu didnt slove the problem. came back the next day.
Old Oct 17, 2003
  #77
Ouse's Avatar
Ouse is an unknown quantity at this point
Can anyone tel me exactly where the IAC is located. I am experiencing the same problems. my idle drops all the time though. i've been to shops and honda and no one can pinpoint the problem. and it doesn't show up on the diagnostics. I replaced the throttle body. is the IAC on the throttle body?
Old Oct 17, 2003
  #78
Ronin's Avatar
Check this thread http://www.7thgencivic.com/forums/sh...5&pagenumber=1
... and maybe PM the author Pharah about your IAC question
Old Oct 24, 2003
  #79
Voiceofid's Avatar
End Bringer
Originally posted by mykel115
I think what happen there is everytime you press the brake pedal The alternetor add up a load on your engine thats why it make the idling more lower. That also apply to power steering and Aircon any mechanism that add load to the engine make the idle low. I mean when your Idle valve having problem controlling your Idle you must have it check. the dealer mentioning about booster at work that everytime a load add up to your engine it automatic higher the idling speed. It show me how it works. He let me open my Aircon Ok I see the Idling going up. he show me when i turn my steering wheel thats Power steering add up load to an engine I saw it higher the Idle of engine. Then when you press the brake ok it also add up load to alternator Brake light remember.
when you put a accessory load on your engine, your engine suppose to automatically increase rpm, not decrease
such as, when you turn your powersteering, the engine should sound louder (if you have sri or cai)
Old Sep 23, 2005
  #80
Gardener's Avatar
Gardener is an unknown quantity at this point
Elsewhere on this site I found reference to the Service Bulletin 02-083 "2001-02 Civic: Stalls Intermittently After a Stop". Any comments about whether this fixes the problem?
Gardener
Old Sep 23, 2005
  #81
streetglower's Avatar
Gardener
http://www.geocities.com/pfeifferper...AfteraStop.pdf
fixing this problem requires the PCM to be updated. And please lets not bring back dead threads. start a new one, I dont mind.
docmartin14
Jul 30, 2015 11:26 AM
The Big Dutch
Jun 9, 2015 07:49 PM
Blazz
Jun 4, 2015 01:04 AM
crowtoo
May 11, 2015 06:50 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
