rattling noise when accelerating
Old Dec 17, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
well after i got my rsr ex mag exhaust and random tech cat on a while back i would always here a rattling noise, like a bolt is rattling kinda noise, from the front of the car so i decided to check the bolts and every one of em are completely tightened down or tightened enough that they shouldnt rattle. i seriously dont know where this rattling is comin from and it really only does it when under wot or accelerating. it comes from the front of the car like it could be the heatshield on the header or im just missing something...any ideas guys and solutions?
Old Dec 17, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
sounds like your heat shield is loose or making contact with something
Old Dec 17, 2005
crazyasian's Avatar
i might just pull it off tommorrow morning before i head off to work to see if that works. is there anything that i need to do as i pull off the heatshield? cause when i looked at it there were couple bolts that looked like it held the shield and header on.
Old Dec 17, 2005
i wouldnt pull it off just tighten all the bolts.
Old Dec 18, 2005
crazyasian's Avatar
i prob could that but wouldnt it just save me the trouble even if i do tighten the bolts and that it fixes it or not. ill see if it goes away if i tighten up the bolts if it doesnt ill just pull it off later
Old Dec 18, 2005
its prolly the exhaust hitting the rear sway bar. i have rsr and no rattles. but it could be the cat making the downpipe touch the car.
Old Dec 19, 2005
crazyasian's Avatar
i doubt its the exhaust hitting the sway bar cause i hear it from the front and it is like a bolt rattling sound. i noe the downpipe is making the cat touch the car cause it def rattles and makes alot of vibrations right at the shifter. its more of a suttle sound but you can still hear it like its almost like its the bolts at the header-downpipe. i tightened down the bolts there like crazy so its def not those. im gonna try tightening the heatshield and if that works it was it if not idk
Old Dec 19, 2005
EclecticVISIONS's Avatar
EclecticVISIONS is on a distinguished road
do you have a cold air intake? could be the piping hitting the frame near the front pass. wheel
Old Dec 19, 2005
crazyasian's Avatar
naw i got K&N SRI Typhoon
Old Dec 21, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
I have the same problem too after I lifted my car for the winter but mine sort of sounds like a plastic card being held next to spokes on a bycicle and rode on
Old Dec 21, 2005
fbodysrule's Avatar
fbodysrule is an unknown quantity at this point
You shouldnt remove the heat shield, it could cause your car to heat up (and burn your passengers asses lol)
15EXCoupe
Jul 30, 2015 12:59 PM
mikebj23
Jul 28, 2015 08:08 PM
Yazan93
Jul 14, 2015 08:56 PM
fvckbg
Jul 7, 2015 07:08 PM
