Think I may have a problem.
Old Dec 3, 2005
nytroph's Avatar
nytroph is an unknown quantity at this point
Unhappy Think I may have a problem.
I have 98K on my 01 Civic EX sedan, and I feel like I have no power anymore. I step on the gas and the higher the rpm the more I hear a ticking noise from the motor, I think it may need a valve adjustment or something of that nature but I'm not sure the car is bone stock so there isn't anything aftermarket that could be causing my loss of power and the ticking noise as the rpm's climb, the motor just sounds like its got nothing left. My poor car sounds like its screaming just going 70+mph on the highway. Does anyone know what I should look into getting done to help fix this?
Old Dec 3, 2005
Jrfish007's Avatar
Check all the normal stuff, PCV valve, air filter, plugs, wire ect. Afterthat I would check the valve clearances, but this sounds like a little more serious than that. If you can't figure out, better take it to a shop, because that kind of power lose is never a good thing.
Old Dec 3, 2005
tfnaaf's Avatar
BLDNPSI Mod
sound could be the valve clearance, power could also be associated witht eh valves. Air filter, fuel filter, spark plugs would be a real good start! Fuel filter is pricey as its part of the fuel pump carriage.
Old Dec 5, 2005
AlienX's Avatar
AlienX will become famous soon enough
check your timing, and ur belt.. toyota rav had this prob also... just clicks. valve adjustment might be needed if any have slipped.
added: wait.. that would require u to drive :P try using a blow dryer to unfreeze ur brakes/line
Old Dec 5, 2005
check compression?
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
IronFist
Sep 25, 2015 07:13 PM
Skunkone
Sep 24, 2015 04:38 PM
curaze
Sep 22, 2015 08:27 AM
