Having crazy headlight problem, maybe sombody knows??
Old Nov 14, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Hey, im having a problem as where one of my headlights works fine, but the other one displays no light during DRL, and only daytime running lights when the headlights are on
Anyone with any suggestions. I've already checked the fuses under the steering column. HELP?
Old Nov 14, 2005
what about the fuses under the hood next to the battery?
Old Nov 14, 2005
i did not see any fuses to do with lighting there?
Old Nov 15, 2005
i think im going to take it to acura to find out whats going on??
Old Nov 15, 2005
divajz's Avatar
divajz is an unknown quantity at this point
take both headlights off and look at the way you wired them. does water get into ur headlights?
Old Nov 15, 2005
no water...damn this is pissing me off!
their also seems to be a slight delay in the dim headlight when you turn it on, maybe 1-2 seconds
Old Nov 15, 2005
I had this same issue with my tails. Clean the sockets and check the wiring!
Old Nov 15, 2005
nova4dr_racer's Avatar
nova4dr_racer is an unknown quantity at this point
same here .. take ur time unless its snowing up where u live. remove ur bumper and the headlights and check em out.. if no bulbs are burnt and no fuses are burnt either and all the wires are connected.. then sonsider bringing it in.
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
usajags84
15
Aug 19, 2015 03:12 AM
stryder12
Jun 30, 2015 08:33 PM
nontypical
May 4, 2015 04:10 PM
shaejb15
Apr 26, 2015 07:44 PM
