engine noise
Old Nov 3, 2005
pmontoya4321's Avatar
pmontoya4321 is an unknown quantity at this point
engine noise
I am having problems with my car and I need help.
I have an engine noise that sounds like it is coming from the top of the engine
and code P1259 which is a VTEC system malflunction. So far I have had my valves adjusted and have switch out my VTEC Solenoid but it hasn't fixed the problem. I don't know if it bad fuel or it is caused by the tornado fuel saver that I installed. Could it be caused by a clogged fuel filter or the fuel regulator or the pump.
Does anyone have an idea of what it could be?
Old Nov 3, 2005
well the tornado might have broken and the engine sucked in some pieces. why would you do that to your car. anyway, it could be other things but usually vtec malfunction is caused by clogged oil passages, vtec solenoid, and in rare cases the ecu messing up. Remember the vtec relies on many factors including throttle position, rpm, oil pressure, temperature, and sensor voltage. So it could be some faulty throttle body sensor or something bad in the engine, or varying cylinder compression. do a compression test and then run some lubecontrol.com products to clear up the injectors and oil. but it seems like a bigger problem somewhere.
Old Nov 4, 2005
Jrfish007's Avatar
Yeah, oil pressure is what the VTEC system uses to engage, check your oil and oil filter.
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
