injectors
Old Oct 19, 2005
mishkakasalapiy's Avatar
mishkakasalapiy is an unknown quantity at this point
injectors
i have 370cc rc injectors and vafc controller installed on my 2000 si. now the rpms dont go past 3000 rpms. when you press the gas farther in and hold it there it seems like the car is gonna stall and when you let go of the gas it does stall.any idea what can be the problem?
how many cc's are the stock hondas injectors?
should i just take out the 370cc injectors and vafc controler and use stock injectors.
Old Oct 20, 2005
streetglower's Avatar
I dont know if that is related to your problem but it may be, but unless you are turboed or something there is no need for bigger injectors. the only time you need bigger injectors is when you have a big increase in air flow. You might be getting too much fuel which interupts the air/fuel mixture and causes it to almost stall when you give it gas.
Try putting the stock injectors back in and see if the issue goes away.
runawaykinms
15
Mar 22, 2019 10:32 AM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 9, 2015 05:55 PM
