Is my clutch not disengaging?
Old Sep 27, 2005
Rufus's Avatar
Ok so here's the scoop. My clutch has slowly been dieing. It's not very bad but to the point where if I drop a gear it clearly slips. So the other night I'm getting on the freeway and it won't go into 4th. Now the car drives fine still with clutch if I don't beat on it so this seemed akward.
Now it's difficult to get it into gear, but if the car is off it will go into any gear I want. However, when in second if I take my foot off the brake it pulls the car. The symptoms all say that the clutch is not disengaging completely.
So the question is this: Is the new clutch I'm about to put in going to solve this issue or is something else going on?
Old Sep 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
As long as you're planning on replacing the throwout bearing with it, I think you should be fine with the replacement plan. It sounds like its on the outs.
When you get it apart look at the clutch hub, the pressure plate springs and the throwout bearing/fork. Make sure they're all ok.
Old Sep 27, 2005
turboengnr's Avatar
DONT PANIC
a burned up clutch should not make it harder to physically put it into gear.
If you burned up a clutch with just an sri and a port job, then you probably beat the **** out of it quite often. Maybe speed shifting and/or skipping gears.
pull your tranny apart and check your syncros.
Old Sep 27, 2005
Rufus's Avatar
I actually have a spare tranny. Maybe I should just be safe and put it in
Old Sep 27, 2005
Rufus's Avatar
Then why does it go into gear without issue when the car is off?
Old Sep 27, 2005
turboengnr's Avatar
DONT PANIC
because the gears arent spinning at all. The syncros dont have to align as much
Old Sep 28, 2005
Rufus's Avatar
Ok so here's a real technical question. I have a spare low mileage LX tranny. I have an 03 EX. Now I don't want to use the gears from the LX as they are different, however, can I salvage the syncros and bearings from the LX and put them into my Ex tranny. I have had bearing noise since about 30K on the car. The car has 81K on it now. I don't beat the tranny but I do take it to 5-6K pretty often.
Old Sep 28, 2005
turboengnr's Avatar
DONT PANIC
I dont see why not. I would assume that they would be the same. I do know that the bearings out of an older d-series tranny will not work. I am not sure of the synchros though. So i guess you could do some experimenting and tell us what you find out.
Old Sep 28, 2005
Jrfish007's Avatar
Better check with Honda first... call up one dealer and ask for the parts number and price for the syncros on the LX tranny. The call up a different dealer ask them for the part numbers on the '03 EX tranny. make sure to mention the year of the LX, I think some stuff changed between the '03 and '04... I forget what though.
Old Sep 28, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Have you checked or changed the fluid lately?
Old Sep 30, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
smartest point i have heard. rep 4 u
Old Sep 30, 2005
Rufus's Avatar
lol. Oh yeah the fluid was fine but I changed it anyway. Still has the same issue. A close buddy who wrenches for a living still thinks it's the clutch. I'll know by this weekend...
Old Sep 30, 2005
univox's Avatar
univox is an unknown quantity at this point
If your clutch isn't disengaging fully, I'd look into getting the pedal adjusted, checking the clutch fluid and making sure the clutch cylinder is working properly.
I doubt a new clutch would fix your disengagement issue, but your disengagement issue will cause excessive wear on your new clutch.
danace99
Oct 17, 2015 02:51 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
Klame9420
Sep 7, 2015 10:03 PM
