so now i have a wiring problem
Old Sep 2, 2005
scarypunk's Avatar
scarypunk has a little shameless behaviour in the past
i took the bubl out, and it looked toasted, put a new one in, and nothing... all the fuses are good, and now my DRL wont even go on .. what could be the problem and where do i start ? help i need my lighs to see
Old Sep 2, 2005
djmota's Avatar
do your highbeams work? there was a recall about the headlight switch melting and causing this problem. If yours has not been replaced you should take it to a dealer to check out and fix for free.
Old Sep 2, 2005
scarypunk's Avatar
my highbeam on that one side is out too
but will they still work on it if there is after market headlights?
and if it wasnt bought from a dealship ?
Old Sep 2, 2005
zen_master's Avatar
BE CAREFUL and don't play around too much with that headlight switch for now........
if the case worsen, it might burn the wiring harness.....somewhere you can't tell.....
be sure to check the recall for your car....and make sure the switch is OK.....it's a bit hard though....
GL man..
Old Sep 2, 2005
streetglower's Avatar
to really find out what is going on, you need to pull a wiring diagram for the DRL circuit and start from there.
Now is this only happening on one side?
Old Sep 2, 2005
scarypunk's Avatar
yes it is only happening on one side, i called there dealership and there is no out standing recalls on my car. the turn signal works and i can turn on the parking lights, but nite lights and high beams dont work on one side. i dont really care much about the DRL but i want my lights so i can see at nite .. duh
Old Sep 2, 2005
Ok, so one headlight doesnt come on when you turn the headlights on, and the DRL dont work at all, correct? And the parking lights work, but the small driving lights under the parking lights dont work? correct?
And what aftermarket headlights do you have?
Also I know you said your light originally burnt out in another thread, and I need to know if everything was working all correctly before you put in this new bulb?
Old Sep 2, 2005
scarypunk's Avatar
i have sonar projectors the turn light works and that bulb that is with it (same houing) works. high beams and low beams work.
pulled out to see if it was the build and it looks shot, put a new one in.. and nothing.
Old Sep 2, 2005
scarypunk's Avatar
and its just the passanger side
Old Sep 2, 2005
CraigW's Avatar
I have some wiring for info for headlights and also certain Canada models that use DRL (not sure what year or body style) PM with E-Mail and I will send them to you. The circuits should be quite simple to trouble-shoot.
Old Sep 2, 2005
scarypunk's Avatar
i went out and picked up 2 more lights for the nite. but now one of them is dim ( NOT THE SIDE THAT WAS HAVING THE PROBLEM) but the other side. and it seems every bulb is lite up now..
its very weird
aim - scarypunk128 / msn scarypunk@hotmail.com
someone help me out .. i live in ottawa if anyone can make it overhere
Old Sep 2, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
sounds to me like you have a bad wire, or you have a bad headlight wire harness(where the headlight housing hooks into the back of the housing and runs to the battery). Just take it to honda if still under warranty.
Old Sep 2, 2005
scarypunk's Avatar
its sonar projectors, i dont think the dealer will do anything
Old Sep 3, 2005
scarypunk's Avatar
one leadlight is dim
what the heck is wrong here .. .. the head light is all dim, even the highbeam and everything.. may be a grounding issure, but where does the headlight ground ? .. ive been searching everywhere
Old Sep 3, 2005
just buy a new wire harness. all plug and play and your lights will be brighter than stock You might have a defective combo switch thats causin the problem. There was a recall for that.
Old Sep 3, 2005
scarypunk's Avatar
where do i get one, do you have a pic of it ?
Old Sep 3, 2005
scarypunk's Avatar
the dealer did say all the recalls were up to date
Old Sep 3, 2005
I merged your 2 threads together.
Well from when I helped you out last night, we pretty much eliminated the fact that your projecter harness was the problem. that why I had you unhook the projector harness from the factory harness and install and OEM bulb in the factory harness and see if it is still dim and you said yes.
Go to the store and buy a multimeter, thats really how you are going to figure out where the problem is coming from. You need to see what kind of voltage you are getting at the headlight. that will tell me what is going on in your headlight circuit.
And as gearbox said, it could be traced up to a bad combo switch.
Old Sep 3, 2005
scarypunk's Avatar
what is a combo siwtch, ill got buy a multimetre now.
Old Sep 3, 2005
the combo switch is basically the switch on your steering colum that controls your turn signals and the headlights (high and low beam).
But yes a mulitmeter would help out alot. it will tell you were to start looking for problems at.
Old Sep 3, 2005
scarypunk's Avatar
^^^ ill be back in 30 min, yu'd better get your butt on aim and help me fix this'
4 banger
Jun 5, 2015 01:44 AM
dinsum
May 28, 2015 09:30 PM
pincookie1
May 4, 2015 12:22 PM
Dmitri
123
Oct 13, 2005 08:01 PM
blackbullet
Dec 1, 2001 03:44 PM
