transmission grinding
Old Aug 5, 2005
peimp's Avatar
peimp is an unknown quantity at this point
hey guys, ive been searching on here, but no one seems to have the same problem, or so i can tell. My tranny is grinding in first and second, maybe other gears too, i really cant tell. its only when i start off, kinda of a wierd whizzing grinding noise ( not super bad). its an 02 lx, boosted with the original cluch. 27,000 miles. any suggestions? i think i might take it to a transmission shop tommorow. also, what is the general price range for replacing the clutch. ( the problem i suspect)
thanks!
Old Aug 5, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
400 for clutch
Could prob put it in yourself in a work day.
Old Aug 5, 2005
peimp's Avatar
so a new clutch would be 400? is that for a good aftermarket one or oem? also, does it sound like the clutch is my problem? thanks for the help!
Old Aug 5, 2005
Wolfgang5884's Avatar
sounds like the clutch to me. Not too much info to go on.
Old Aug 6, 2005
peimp's Avatar
k i just took it to a tranny shop. they said it sounded like a throw out bearing. Is that a big job, cost wise? also, while they have it out, is there anything else i should replace? car is a boosted 02 lx with 27000 miles
Old Aug 7, 2005
peimp's Avatar
bump
Old Aug 7, 2005
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Well when they do a clutch they will replace the throw out bearing so I would assume if the bearing goes out first they would wanna do the whole thing. Its gonne be expensive for labor unless you DIY. Since ur car is turbo i bet ur clutch is somewhat worn also. Just have the shop do the whole clutch including the throw out bearing.
Old Aug 7, 2005
02civic_rida's Avatar
if u buy a clutch kit it will have the bearings that u need as well as other needed components.... robear is selling a ACT clutch KIT for just under 300 bux.... ask him about it, im ordering mine tomorrow, my tranny is making the same dayam noice... hope that helps.
Old Aug 12, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
If it's just the bearing I say screw it, just ride the stock clutch till it goes.
Old Aug 13, 2005
turboengnr's Avatar
DONT PANIC
i had this problem.
We figured it was the throw out bearing also, but it ended up being something completely different.
I broke the plastic cage that holds the ball bearings inside the input shaft bearing. In order to check this, you have to completely remove the tranny from the car, split the case, pull out the gears, and check the bearing.
It was only $22 from honda for a new bearing. And luckily, my buddy manages a tranny shop, so i bought him dinner.
siliconvalley
Sep 15, 2015 09:48 PM
Bricoleur
Sep 9, 2015 12:30 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Josh 1973
Sep 7, 2015 10:10 AM
tommycanada
Sep 5, 2015 04:59 PM
