no reverse gear?
Old Jun 11, 2005
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
no reverse gear?
when i went to shoot pool, i backed out of the driveway and everything was fine. when i'm backing out of the pool hall, i put it in reverse and it just grindes. i get home, and it does the same thing. did i loose my reverse gear or something?? i won't loose all the others will i. by the way i just got a new clutch about 10,000 miles ago. and no other gears are affected. and i have a 5 speed.
Old Jun 11, 2005
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
yea same thing was happening with my buddy, but he had hydrolic, we have cable. His prob was the slave cylinder. What you can do to fix is b4 u turn on car, shift to the reverse and turn car on with it in there already.
Old Jun 11, 2005
or, you can shift into a forward gear, then shift into reverse.. apparetly its a common problem with honda tranny's..
if that doent work, do it until it does.... thas what i do..
Old Jun 11, 2005
Al Gore FTW's Avatar
jdmtytedoridori
wrong, we have hydraulic clutches. oh and make sure its actually in gear, sometimes mine wont go all the way into reverse, and it grinds. just take it outta gear and put it back in to make sure.
Old Jun 11, 2005
naw it's in gear the back lights come on and everything. i know what u mean when u said sometimes it's not in gear thought. it used to happen to me, until i changed the clutch, now it goes right into reverse (well it used to). i wonder how much this is going to cost.
Old Jun 11, 2005
Black03civic's Avatar
same here also, sometimes i am stuck in a parking lot for like 10 mins cus it wont go into reverse
Old Jun 11, 2005
so whats the situation?? anyone know how much it is to fix?? cuz i'm getting tired of pushing the car back all the time.
Old Aug 11, 2005
mdb_foxmx's Avatar
mdb_foxmx is an unknown quantity at this point
Well, it sounds like this guy has real problems with reverse gear...don't know what to say. Have it looked at?
As for everyone else, I'd like to confirm that the reverse gear on our transmissions does seem pretty finnicky. I've found that this works every time, however...
If you shift to reverse and actually maintain a firm (not forceful) pull on the shifter as you release the clutch, you'll find that the spurs on the reverse gear will engage normally.
If you just shift, let go, and release the clutch, I'd say at least 1/3 of the time, you'll just grind away.
Old Aug 11, 2005
jdmtytedoridori
^ yeah, thats true ^
Old Aug 11, 2005
Jrfish007's Avatar
Honda does not put a syncro on the reverse gear for the civic, that's why most of you are grinding away. Buy doing what most people are saying, you are just meshing the reverse gear with the speed of the motor, which is what needs to be done.
Now on to your problem, does it ever go into reverse?
What kind of clutch did you have put in?
Was the tranny serviced?
Did the dealer put your clutch in or did a local garage do it?
Help me out with these and I'll see what I can do.
Old Aug 11, 2005
hey i had my tranny serviced. i have a excedy organic clutch. the honda dealership put it in for me. i can find reverse gear, the white back up lights come on, but it just reves. lol i'm tired of pushing the car out of the driveway too.
Old Aug 12, 2005
Jrfish007's Avatar
Man, this isn't sounding good... When does it grind? When you let off the clutch or just when you try to put it in gear?
It's begining to look like your reverse is just simply gone though. Your best bet is probably going to be to get a used tranny put in. You can either get a junkyard tranny (which will be the cheapest) or get a rebuilt one (from someone like Jasper). If you have the money go for a rebuilt one, otherwise a junkyard.
To give you an idea of cost:
I looked up Jasper for a 2003 civic and it was 1449 (comes with 36 month, 76,000 warranty
This guy has an Ebay site and is offering a 12 month 12,000 mile warranty for less than $800 http://cgi.ebay.com/ebaymotors/91-04...91621887QQrdZ1
An ebay tranny costs about 250-300 (I'm thinking a junkyard one should be about the same)
There also some junkyards by me that will sell you a tranny or motor with a small warranty, like they warranty it will start and run, that is what I would look for.
If you want a garage to do it, call as many as possible, try to find a place that specializes in tranny's, and always ask what kind of warranty it comes with and what they do if the tranny they put in is bad.
Also, does anybody know if all the trannies in the 7thgens are the same?
Old Aug 15, 2005
so i just can't have a gear put into my tranny
Old Aug 15, 2005
Jrfish007's Avatar
Well, you can ask, but generally to pull apart a tranny and rebuild it will cost more than simply replacing it. And IMO, a rebuilt tranny is never quite right unless you pay big $$$ and have it done by a very well known company. I mean it can done, sometimes it's cheaper, but generally speaking your reverse went bad for a reason, if they don't find and fix that reason, you might just end up replacing naother and another. On, maybe it was just a bad gear.
nirvanaguy
25
Oct 26, 2017 07:26 PM
velozp
Dec 13, 2015 11:28 AM
curaze
Sep 22, 2015 08:27 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
