Lost radio code
Old Feb 15, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Lost radio code
i disconected my battery to do some work and after i was finished i hooked everthing back up i went to put in the radio code and found out that i lost it. So i contacted my dealership and they said i need 2 tak out the radio and get some numbers off of it so i can get the code. Does any 1 know how 2 remove the radio cause me and my friend could not fighre it out.
Old Feb 15, 2005
jamescardenas07's Avatar
Member
jamescardenas07 is an unknown quantity at this point
pull the radio out, go the the dealership, give the radio the service department so they can check the serial # behind the radio, they will search the database and theyll give u the code. Oh yea be sure u have ur ID and proof of ownership with ya!
Old Feb 15, 2005
Member
oh i didnt read the whole thing. i think theres a DIY on the DIY section
Old Feb 15, 2005
qfinger's Avatar
qfinger is an unknown quantity at this point
Check this out:
http://www.handa-accessories.com/civic/03civaudio.pdf
Old Feb 15, 2005
Member
i didnt read that lolz
Old Feb 15, 2005
i want to put in a aftermarket cd player will my security system still work. At the dealer ship they told me no but i donn.
Old Mar 7, 2005
thoes directons you gave me are they for a 5 speed ?
Old Mar 7, 2005
mexinaction's Avatar
hey i lost my code and the dealer told me that they would have to replace the headunit because there is no way of retrieving the code.
so i ended up buying an aftermarket head unit and then 2 months later i finally found the code. i was about to sell it but now i cant find the damn code again
Old Mar 7, 2005
adgriffi's Avatar
adgriffi is an unknown quantity at this point
03CivicEX4Door... I have the same car and I replaced my HU a week ago....
Use THIS document first (steps 35-37) then pick up with step 4 on the other document:
http://handa-accessories.com/civic/civ03fogs.pdf
mexinaction, I haven't tried it but the feedback makes me think it works:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Mar 7, 2005
IrockCivics's Avatar
check under the fuse box the code might be there, mines was.
Old Mar 7, 2005
Old Mar 15, 2005
i removed 2 screws for the center pannel i donn if their's any more or not but i can't remove the center pannel bracket to release the 9 retaining clips. DID i miss any bolt's or am i just doing something wrong
Old Mar 15, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
You can ask your dealer for the code. However, you'll need the radio serial number before they can look up your code. You'll also need some documents (repair receipts, invoice, insurance paper, ...etc.) to prove that you've had this car for awhile and not look like it's been stolen. To get to the serial number, you'll mostly like need to remove the radio from the dash. Good luck!
Old Mar 16, 2005
FuzzBeC00L's Avatar
Fuzzy Boy
yep just call did that before I didnt even need the serial number just give them ur info thats all
Old Mar 16, 2005
tacheon's Avatar
tacheon is on a distinguished road
You absolutely DO NOT need to remove the radio to obtain the serial code. Also the code sticker is not placed in any particular location on the vehicles. It is up to the dealer and the person doing the pre-delivery inspection whether or not to put a code sticker inside the vehicle somewhere. See attachment for how to obtain your radio serial number when it displays CODE.
Old Mar 16, 2005
clarkscivic's Avatar
clarkscivic is an unknown quantity at this point
Mine was also by the fuse box.
Old Mar 16, 2005
Black03civic's Avatar
THat is some good ish right there. Ill will have to remember that, cus i want to change my battery next week.
Old Mar 16, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
I have a sticker in my glove box. I've heard there may also be a sticker on the underside of the trunk lid.
Old Mar 17, 2005
EX4Dr's Avatar
I guess these new cars have the S/N displayed on the radio. I'd not had the opportunity to use my radio code on my Civic. However, Hondas in the 90's did not display the S/N. One usually would need to take the radio out to look in the back to see the S/N. Well, I guess I'm too old to be up to date on these things.
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
mistermenphis22
Jul 13, 2015 04:43 PM
mapdog
Jun 22, 2015 05:36 AM
paddystrang
May 18, 2015 09:56 PM
