problem can't figure out . . .
Old Feb 1, 2005
choiboy19's Avatar
choiboy19 is an unknown quantity at this point
my battery can hold a charge but i think the battery isn't charging while i'm driving, is it the alternator???
Old Feb 1, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
test the batt to see if its good
if pass load test the alternator should not drop below 13 volts...
Old Feb 1, 2005
opticalvetc's Avatar
opticalvetc is an unknown quantity at this point
why do you think your battary is not charging? Is the battary light on?
Old Feb 1, 2005
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
Get your handy dandy multi meter out and get rid of any static discharge. Check the battery.....if its below 12.45 volts then its bad. This is after you've charged it up......check all your connections between the alternator and the battery to make sure nothing is working loose. If you do this and the everything appears fine.....move on to the alternator.
Old Feb 1, 2005
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
i had the same problem with mine after it was parked for the winter it was the battery.
Old Feb 8, 2005
choiboy19's Avatar
the battery is okay and can hold a charge, but after about 2 weeks, it'll be dead again, is it the alternator?
Old Feb 8, 2005
streetglower's Avatar
does the car die while running? If it dies 2 weeks later, then your battery cant hold a charge. You need to load test the battery. Charge it, then load test it. Apparently the battery is not ok if it dies after 2 weeks. But you need to get specific here.
Old Feb 8, 2005
tacheon's Avatar
tacheon is on a distinguished road
How exactly are you testing this? Just because it can hold a charge doesn't mean the battery is good. You must get the battery load tested to determine if it has the capacity to start your car time after time. If it was your alternator, it would trigger a trouble light most of the time under common failure conditions (eg. brush, slip ring, commuator, stator failure).
ywgflyer
May 15, 2015 05:05 PM
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
RickyRocket
Nov 30, 2001 10:14 AM
