help..car would not start
Old Jan 18, 2005
gOtRyce's Avatar
gOtRyce is an unknown quantity at this point
anyone know what's wrong with my car. this morning it would not start. the battery is ok and the starter was ok, but the car would just not start. it is also like 5 degrees outside. the car would act like it was going to start, but would just not turn over. any ideas?
Old Jan 18, 2005
Turn car to ON position and wait 10 secs to let fuel pressure build. Then try and crank it. Either plugs are getting bad, or the stock battery is frozen. Get an optima.
Old Jan 18, 2005
_Viper_'s Avatar
If it dosnt turn over then its the battery buddy..Get a new battery yes maybe the volts were Ok but the Amps are probably gone on ity ..Rember batteries have a cold cranking ampage on them ...
when thats gone the battery is usually dead
Old Jan 18, 2005
hustlelikem0fo's Avatar
Yup, what they said.
Battery still has a charge to turn on everythign electrical in the car but doesnt have enough juice to crank the motor.
Old Jan 18, 2005
streetglower's Avatar
how do you know the battery and starter are ok? Did load test the battery? Did you do a starter draw test? Most likely it is your battery because of the weather, but like gearbox said, let it build up pressure, then try to start it. Have your battery tested too.
Old Jan 19, 2005
gOtRyce's Avatar
it was the battery. must have been the new us amp i got the other day. that thing drains a lot of energy. i think it is time to get an optima......almost 50k on stock battery. thanks guys.
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
