No more beeping sound
Old Jan 11, 2005
yeehaw's Avatar
yeehaw is an unknown quantity at this point
When you open your car door its suppose to beep and such.
For awhile Id open it and get a half beep.
Now I get no beep at all.
I dont really care but why is it doing that. Id life my car to be perfect and beep normally and not have a re-cursor to an electrical problem.
Old Jan 11, 2005
streetglower's Avatar
you want your car to be perfect huh? Good luck on that one.
Old Jan 11, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Wow, you may have inadvertently done the DIY many people on here are searching for, LOL. Have you checked your door sensors (the ones that pop out when your door is opened)? Do the interior lights still come on when you open the door?
Old Jan 11, 2005
yeehaw's Avatar
Np they dont
Why is this, Id like the beeping and the lights back.
Old Jan 11, 2005
CivicsRdBest's Avatar
check those things first.
Old Jan 12, 2005
TeLLy's Avatar
Check your fuses, then the door sensors...if your warranty is still valid then take er to Honda.
Old Jan 12, 2005
There's a nipple close to where the door latch is. It has to be pressed so it thinks the door is closed. Maybe it's damaged or the wires got messed up. There's a screw holding it on so check that. Otherwise the beep sound comes from the gauge cluster and can't be fixed without replacing it. I have a feeling it's the door sensor tho if the dome light doesn't come on either.
Old Jan 12, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
the car only beeps if your car is in the ignition. if no keys are in then it wont beep when the door is open.
Old Jan 13, 2005
2K1Civic17"Gabe's Avatar
I think I remember car used to beep when the door was open. It doesnt do it anymore. Only with the headlights left on and no key in. Is our car supposed to beep when we first start it as well? Mine doesnt do that.
Old Jan 13, 2005
im stock now! T.T
if the key is in position II it wont beep. If it is in I and driver side door is open, it will beep. I know this because I installed my own ebay alarm.
Old Jan 14, 2005
Revmaster's Avatar
Revmaster is an unknown quantity at this point
Try resetting your ECU.
Old Jan 14, 2005
player's Avatar
it happened to me a while ago, i took it to honda, its the door sensors
Old Jan 14, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i hate that friggin beep
Old Jan 14, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
yea, wiggle ur door sensors, it'll come back, at least mine did, just needs a better connection
Old Jan 15, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
they possible way when it beeps!
1) key in "I" position & driver door is open (sequencial peep)
2) headlights are on & driver door is open (rapid peep)
i say take it back to honda, and have it cover under warranty
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
