Water draining back
Old Nov 1, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Water draining back
I think air conditioning drain is clogged, causing water to drain inside the car near the passenger floor mat area. I know the drain lines can be cleared by inserting a wire with a small hook on the end of the drain tubes to clear out any obstruction. But where exactly is this drain plug located from under the car?
Old Nov 6, 2004
streetglower's Avatar
there is a piece of tubing that has an opening that sticks out under the car, that is where the moisture goes out from the AC. Look under the passanger side to see it.
Old Nov 26, 2004
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've been getting that to sometimes, I knew it was the AC but wasnt sure what. I don't use my AC much. Is that what you do to fix the problem?
Old Nov 26, 2004
I've noticed that the problem exists only if I use the defrost. but yea, I don't use my AC much....
Old Jun 13, 2005
When I take turns with the A/C on I hear a weird gargaling too. I have to try that out, i'll look it up in my Hanes manual.
Old Jul 8, 2005
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
yeah i had the same problem cleared out the drain pipe and it was all gone!
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
ashlava71
May 16, 2015 12:54 PM
markp94
Apr 30, 2015 09:19 PM
Grey
16
Jan 27, 2002 11:34 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
