power steering ??
Old Sep 28, 2004
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
power steering ??
how bad is it if you lose all of your power steering fluid and drive about 4 miles and make a few shape turns ?? thats how far i was from the auto parts store to get more fluid
Old Sep 28, 2004
sdl02's Avatar
sdl02 is an unknown quantity at this point
haha, not good at all really...have someone give you a ride if you can. in my old car my power steering fluid had to be refilled every other day. when it ran out it was horrible to drive-- so don't take the chance if it can be avoided
Old Sep 28, 2004
Danka02's Avatar
SICCMADE
well its not leaking i had to pull the resivor out of the way to put in my new lights and forgot to put it back in its place so when i got to the store my car make this weird noise and my steering is really harder to turn so i look around nothing so when i left i saw this puddle and i thought power steering fluid crap! then i drove 4 miles to get some, put the bottle back in the slot that holds it filled it up started the car and turned the wheel slowly until i got lock to lock now its fine i checked again no leaks from anything but is the 4 miles of driving really bad for it? i'm still getting it looked at just to be sure
Old Sep 29, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
It *could* damage the pump, but I doubt it did.
Old Sep 29, 2004
sdl02's Avatar
^^what he said. i don't think that little episode did anything detrimental to your power steering, and you should be alright . haha, it does suck trying to turn when there is no power steering fluid!
Old Sep 29, 2004
Danka02's Avatar
SICCMADE
yeah it was a bitch tryin to turn with out it
Old Sep 29, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
where do you check/fill the power steering fluid? ??
riley
Old Sep 29, 2004
TeLLy's Avatar
Yes, it's an Acura EL
The reservoir is right by the alt pulley....I accidentally cut the tubing when I installed my first aftermarket headlights cause I forgot to put it back in its bracket....the tube leaned against the alt pulley, which cut through it, and I lost fluid.
There's a min/max fill line on the reservoir, and you can fill right from the top.
Old Sep 29, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
oh i thought that was some kinda oil nvm .lol the resevior that clips into the metal brackette. mm hmmm i cant spell
Old Sep 29, 2004
habs_hater's Avatar
habs_hater is an unknown quantity at this point
you should bleed the system as you probably now have lots of air in the system from running it with out fluid. The air will affect performance (heat build up, momentary loss of steering) and can sometimes cause the power steering to be really noisey.
NoobyKid
Jul 13, 2015 07:53 AM
hans.pcguy
Jul 12, 2015 12:19 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
