Tranny Dip Stick Not Tight...!
Old Aug 31, 2004
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
Exclamation Tranny Dip Stick Not Tight...!
Is it just my car, or does anyone else notice the tranny dip stick is very loose? I would think if I hit the right bump the thing might fly out and wind up on the street or something. I changed my tranny fluid for the first time (It's been done before but I never did it) and that's when I noticed it. The dip stick kinda just sits there and doesn't feel like it seals anything.
Looking for ideas to seal it better. It seems like the dip stick isn't even the correct size. Maybe the Honda techs put the wrong one back in my car... It wouldn't surprise me.
Old Aug 31, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
It should have o-rings to secure the dip stick in place. And trust me. That dip stick is long enough. So it will not fly off if you tried to hit any bumps.
Old Aug 31, 2004
streetglower's Avatar
I have noticed the same thing. it isnt loose, but when you pull it out, it comes out really easy.
But like HappyGilmore said, it shouldnt ever come out if you hit any bumps
Old Aug 31, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Mine is the same...no problems here...
Old Aug 31, 2004
The fitting is black and it tapers off to where the metal dipstick enters into it. But even at the largest part of the tapered base it still just kinda sits in there, not very tight at all. I'm just afraid with a weak seal that dirt/dust can find it's way into my transmission. I would think Honda would make a tighter plug for this. Hey, maybe that's why I have so many tranny issues huh!
I might rig up something to make the plug fit a little better. Maybe some electrical tape wrapped around the top or something, who knows. Just another weekend project!
Old Aug 31, 2004
It's gonna be okay. Just gives you a reason to change the fluid more often!
Old Sep 3, 2004
024drlx's Avatar
024drlx is an unknown quantity at this point
honda tech at here in dallas, tx said it is like that. never had a problem so i guess it is ok.
Old Sep 3, 2004
Tip:
Put one piece of electrical tape about six inches long and wrap it around the top or larger area of the black part and it fits snug like a glove! I tried this the other night. Now I have just the right amount of seal and it isn't loose at all.
Old Jun 14, 2012
meangreenmachin's Avatar
meangreenmachin is an unknown quantity at this point
Re: Tranny Dip Stick Not Tight...!
same thing happened to me ,but mine auto tighened own it's own hot to cold ,no tape needed that is bs like all other treads on here trail and...................
Old Jun 14, 2012
put it in hot Don't touch it till the engine is cool and then try and pull it out it is like pulling two dogs apart!!!!!!!!!!!!!!!!!!!!!!!!!! krazy right..... worked for me by my own shade tree, meangreenmachine.............
Old Jun 14, 2012
not needed...................read post thank-you very much motorhead (meangreenmachine)................try it......................
Old Jun 14, 2012
bs trash in tranny does not mix duh............................................... .........
Old Jun 14, 2012
Why wouldn't anyone just spend the $11 for a new dipstick that will fit properly?
Oh, wait. That would be too easy.
They shrink the rubber over time.
By 100k, most fit loose.
Some even fall out and get lost.
Some people STILL won't buy a fresh one for $11.
Old Jun 15, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
I hear what you're saying, but mine came for the factory that way. When I checked my trans fluid for the first time 7 years ago with about 20k on it, the dipstick was extremely loose then, to the point I turned in such away to wedge it in there.
And I don't know if you looked, but the people way above are complaining from 04 post when at most they may have had an 01 and it was 3 years old.
If they've improved the design on the dipstick or I just received a defective one, I will gladly spend the money to replace it.
Old Jun 15, 2012
they have an updated part, it fits much tighter, but be sure you wipe the hole so that fluid doesnt get on the rubber and shrink it. if you want the super tight new feeling, you prolly need a new one every few yrs because rubber wears out. the old dipstick was a design flaw and loose from the factory.
Old Jun 15, 2012
Matt_75's Avatar
Good to know. I have always wiped the hole. I'm guessing my original from the factory was the design flaw. I will place my order for a new one ASAP.
Old Jun 15, 2012
CraigW's Avatar
WOW, blast from the past.
Electrical tape and ATF fluid may not make for a good combination though.
Yes, 7th gens get the improved part # for tighter fit.
Old Jun 15, 2012
Matt_75's Avatar
The stealer ship had one in stock. The fit is a night and day difference.
You lied ezone. You said it would be $11, it was $14. I broke the bank LOL .
Anyway, I attached a picture for comparison.
Name:	Trans dipstick.jpg
Old Jun 15, 2012
Originally Posted by Matt_75
The stealer ship
Yeah, I F'n lied to you.
The REAL MSRP is $10.52 (USD) for part # 25610-PLX-003. http://www.hondaautomotiveparts.com/...EEDOMETER+GEAR
Now then: Is your state tax around 34%, or does your dealer charge that much for the privilege of setting your dirty feet inside their fabulous building?
It's still dirt cheap IMO.
Old Jun 15, 2012
Matt_75's Avatar
It is dirt cheap IMO too. It was actually $13.68 plus tax which came out to $14.32.
I was just messing with you about the lying to me thing. I knew it was going to be more expensive than the standard MSRP if I bought it here in Hawaii from the dealership.
Most of the time I use Majestic because about 90% of the time it is cheaper even with shipping and sales tax. In this case, the dealer ship was cheaper. It would have cost me $20 and change with shipping and tax from majestic.
Glad someone chimed in up the updated part because it fits like a glove now.
Old Jun 15, 2012
OOOooohh, I would think it would be about double the list price out there! You know fuel for the ship (or plane) that got it there probably cost a lot. Gotta recoup that expense somewhere!
For everyone else reading: Dealers are free to set their own prices. MSRP is only a "Suggested Retail Price".
Decent dealers you might bargain down to real MSRP if you already know what that number really is.
Old Jun 15, 2012
04 Honda Civic's Avatar
I buy my stuff online. Works well until I need a small part. Then I go to the dealer.
Old Jul 28, 2017
Kingcredible's Avatar
Kingcredible is an unknown quantity at this point
I had the same problem on my 02 civic. Loose as a toddler's shoe laces. Bought the replacement dipstick from hondapartsnow and it sits tight with no play.
Old Sep 25, 2023
Missieshain's Avatar
Missieshain is an unknown quantity at this point
Originally Posted by UltimateWarrior
Is it just my car, or does anyone else notice the tranny dip stick is very loose? I would think if I hit the right bump the thing might fly out and wind up on the street or something. I changed my tranny fluid for the first time (It's been done before but I never did it) and that's when I noticed it. Th dip stick kinda just sits there and doesn't feel like it seals anything.
no b.s. the man speaks the truth!! I'm on here trying to find another dipstick that will seal it..I think Amazon is
the cheapest and fastest route I can go ..just need to get it fixed asap
Old Jul 4, 2025
pippo's Avatar
pippo is an unknown quantity at this point
So, just found this old thread, and wanted to ask about my tranny fluid leak. Could fluid be leaking/seeping/jumping from that loose plug or must it be coming from seepage from the seals on the tranny case itself? I found pink fluid on the bottom of my case.
UltraHDGames
Jun 8, 2016 05:16 PM
mistahlorax13
21
Nov 18, 2015 12:47 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
speedlever
Sep 24, 2015 07:18 PM
dantheman42
Sep 4, 2015 01:10 PM
