i'am having trouble with my civic i found oil in my spark plugs making my car run bad...i was wondering if i were to change the valve cover seal will it prevent oil from going to my spark plugs...is this something that a i have to take my car to a mechanic to replace or can anybody do it...
what do i need to take out to change the seal.....
Are you having the CEL or MIL coming on? Do you see any traces of coolant or greenish tint on the spark plugs?
When does the symptom usually happen or is it the whole time?
^^^^^its just plain oil on it......no traces of coolant or greenish tint on the spark plugs
What year civic do you have????
Probably the valve cover seals, from your last reply.
Jesus, people... a little detail would be helpful.
"Ummm..... I have a Car, and it leaks, what could be wrong???"
A model and year would be VERY helpful to answer your questions, as well as are the plugs full of oil on the electrode side, or on the boot side?
I'm now assuming the boot side since you mentioned PLUG CABLES. So you must have a 6th gen or less???
Yes could just be the valve cover gasket. It could cause a nasty run.
