Question about TSB information?
Old Jun 19, 2004
streetglower's Avatar
Arrow Question about TSB information?
Here is the list I got
Automotive Recalls and Technical Service Bulletins for 2001 Honda Civic EX Coupe L4-1668cc 1.7L SOHC (VTEC-E) MFI.
Provided by ALLDATA
Safety Recalls
TSB Number Issue Date TSB Title 02-004 FEB 02 Recall - Rear Seat Belt Buckle Non-Compliance
01-095 OCT 01 Recall - Air Cleaner Housing Inspection/Replacement
01-059 JUN 01 Recall - Fuel Fill Hose Clamp Tightness
01-060 JUN 01 Recall - Fuel Pump Connector Corrosion
Service Bulletins
TSB Number Issue Date TSB Title 00-064 AUG 03 Body - Windshield Molding is Deformed
01-028 AUG 03 Interior - Right Hand Dashboard Creaking Noise
03-039 JUL 03 Suspension - Front Suspension Knock/Pop/Squeak
98-018 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
03-009 JUN 03 M/T - Clicking Noise Driving in 2nd Gear
00-088 JUN 03 Brakes - Brake Disc Refinishing Guideline
02-070 MAY 03 Suspension - Squeak From Rear Suspension
01-053 APR 03 Antitheft System - Type 3 System Operation/Programming
02-061 APR 03 Body - Trunk Lid is Difficult to Close
02-034 APR 03 Restraint System - SRS Indicator ON/Multiple DTC's Set
03-010 APR 03 Body - Front Bumper Spoiler Loose/Detached
98-011 APR 03 Keyless Entry - Transmitter ID/Programming
03-020 MAR 03 Engine Controls/Emissions - OBD II DTC's & Monitors
02-054 OCT 02 Restraint System - 'SIDE AIRBAG OFF' Indicator ON
02-052 AUG 02 Restraint System - Occupant Detection Initialization
02-039 JUL 02 M/T - Shift Lever Difficult to Move/Hard Shifting
02-034 JUN 02 Restraint System - SRS Indicator ON/DTC's Set
02-026 MAY 02 Emissions - MIL ON With DTC P1457 (EVAP) Set
01-057 APR 02 Interior - Driver's Seat Rocks Back and Forth
02-024 APR 02 Interior/Lighting - High Mount Brake Light Rattles
00-095 MAR 02 Body - Moonroof Seal Squeaks
02-008 MAR 02 Body - Trunk Release Handle Inoperative
02-009 FEB 02 Interior - Rear Seat Back Lock Hard to Turn
02-002 JAN 02 M/T - Clutch Pedal Squeak Upon Application
01-054 NOV 01 Front Suspension - Popping/Crunching/Knocking Noise
01-076 NOV 01 Rear Bumper - Paint Peeling Below Taillights
98-061 NOV 01 A/T - In-Warranty Exchange Program
01-091 OCT 01 Windshield - Cracks At Lower Corners
01-081 OCT 01 M/T - Stiff Shifting/Pops Out Of Gear
01-083 OCT 01 Engine - Rattle/MIL ON/DTC P1361 or P1362 Set
01-086 OCT 01 Steering Wheel - Feels Stiff/Grinding Noise When Turning
01-089 SEP 01 A/C, Dash - Center Vents Hard to Adjust
01-043 SEP 01 Front Subframe - Removal Adapter
01-068 AUG 01 Body - Roof Molding Warped/Loose
00-088 AUG 01 Brake Discs - Refinishing Guidelines
01-040 AUG 01 Engine Rear Main Oil Seal - Leaks
01-065 AUG 01 SRS Control Unit - Programming Change
01-063 JUL 01 Fog Light Lens - Cracked/Damaged
01-058 JUL 01 Instruments - Fuel Gauge Inaccurate on an Incline
01-045 JUN 01 Cruise Control - Cruise Control Indicator Always ON
01-049 MAY 01 A/T - MIL ON/DTC P0740 Set
01-029 MAY 01 Engine Controls - DTC Capture and Downloading
01-042 APR 01 Rear Shelf/Speaker - Noise/Vibration
01-039 APR 01 Body - Front Air Spoiler Loose/Coming OFF
00-004 MAR 01 Hood - Rattles on Rough Roads
00-099 DEC 00 Wiring Terminal - Repair Instructions
00-088 NOV 00 Brake Rotor - Refinishing Guidelines
00-089 OCT 00 Supplemental Restraint System - Inspection
00-074 OCT 00 Alternator - Bolt Tightening Sequence Manual Update
00-069 SEP 00 PDI - Procedures/New Model Information
00-063 AUG 00 Special Tool - Chassis EAR(TM), Diagnostic Tool
00-044 MAY 00 Quarter Glass - Rattle/Squeak While Driving
[ Select a different engine | Select a different model | Select a different make | Select a different year ]
ALLDATA has obtained this information from the original equipment manufacturers and others and ALLDATA believes it to be reliable. However, ALLDATA makes no warranty regarding the information, express or implied, and accepts no responsibility for the accurancy or completeness of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or misuse of this information, including, but not limited to, any direct, indirect, incidental, special or consequential damages arising out of the use or inability to use this information.
Viton® is a registered trademark of DuPont Dow Elastomers
Loctite® is a registered trademark of Loctite Corp.
Teflon® is a registered trademark of E.I. DuPont de Nours & Co., Inc.
Dexron® is a registered trademark of General Motors Corporation.
Bendix® is a registered trademark of Allied Signal, Inc.
Goodwrench® is a registered trademark of General Motors Corporation.
Helicoil® is a registered trademark of Emhart Industries Inc.
Plastigage® is a registered trademark of AE Clevite, Inc.
Torx® is a registered trademark of Camcar Div. of Textron, Inc.
Motorcraft® is a registered trademark of Ford Motor Company.
Havoline® is a registered trademark of Texaco Lubricants Co.
DEX-COOL® is a registered trademark of ACDelco, Inc.
Optikleen® is a registered trademark of General Motors Corporation.
Lubriplate® is a registered trademark of Fiske Brothers Refining Co.
Copyright © 1996-2004 ALLDATA LLC. All Rights Reserved.
Now under the first service bulletin, recall in Aug. 03 winshield molding is deformed. Well my windshield molding is coming apart at the top. Just in the corner. Would that be under the recall. Can I just take it to honda and show them the TSB and they will replace it for free.
Old Jun 21, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Most likely yes ... most dealers will fix your problem if you show them the TSB printout
Old Jun 21, 2004
Even if it is a service bulletin?
Old Jun 22, 2004
Ronin's Avatar
yes, even service bulletins
Old Jun 22, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
where do I get this information? and how do i get honda to check it out and fix it
Old Jun 22, 2004
Ronin's Avatar
There are a few TSB's (not all) posted in the sticky thread at the top of this forum
sch2cm
Jul 21, 2015 09:58 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Roman Rembacz
Jul 16, 2015 12:30 PM
NoobyKid
Jul 13, 2015 07:53 AM
