Wet Carpets - HELP!
Old May 22, 2004
909's Avatar
909
909 will become famous soon enough
Wet Carpets - HELP!
2002 Si coupe.
So I just spent the weekend removing most of the door moulding.
Removed the front and rear seats, saftey belt assembly, center console.
Ripped the carpet out (cut where it's attached under the console) threw it in a commercial laundry machine - then in a commercial dryer for an hour - BONE DRY - Looked and smelled awesome after it was all re-installed......
Reinstalled EVERYTHING!
Rained over the next few days, wet carpets under the driverside mat.
WTF?
Where could the water be comming from?
If I don't tackle this problem, water will eventually corrode the metal floor, and plus it'll start to stink - mold- bacteria.
PLease Help.
Old May 22, 2004
Da1lyDr1ver's Avatar
so you have the all weather RUBBER mats? i have those and those things suck. the grooves in the mat arent deep enough and when it rains or snows, whenever i stop, all the water slides forward going into my real carpet. i find it best that when it gets too wet or rainy outside, then i turn on the air to blow at the floors. AC works best because it takes out the moisture (sp) in the air so it'll dry better.
Old May 22, 2004
civic01vtec's Avatar
are you saying that you have water coming into the vehicle ???
Did you drill the firewall to run any wires ????
Old May 23, 2004
7gencivicboi's Avatar
7gencivicboi is an unknown quantity at this point
rent a carpet cleaner and get rid of the water fast
Old May 23, 2004
909's Avatar
909
Da1lyDr1ver "..so you have the all weather RUBBER mats? i have those and those things suck..."
..Word... the water source seems to be comming from the floor under the drivers side, then migrates to the surface through capilliary action, and gets sandwiched between the carpet and the rubber mat.
civic01vtec: "...are you saying that you have water coming into the vehicle ??? Did you drill the firewall to run any wires? ..."
Exactly. water _IS_ comming into the vehicle - and I can't seem to find the entry point. I never personally drilled holes in the firewall for wires to run an amp, but the previous owner had an amp installed at one time. Could that be it? Someone told me my windshield might be leaky or the drain is clogged, but I can't seem to find it.
Old May 23, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I have the same problem too! Honda says its the power wire i ran... but thats on the other side of the car on the passenger side... but only the driver side is wet. i'm gonna rewire the power wire to see if it makes a difference... probably after finals... but if you figure it out before me... pm me and lettme know.. thx
Old May 24, 2004
909's Avatar
909
trunk has a puddle too, anyone have a solution?
Old May 24, 2004
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Get a friend, goto the manual carwash and go at it and see if water appears, have them alrt you when it does.
Its new enough that Honda should fix it for free yes?
Old May 24, 2004
vietfob714's Avatar
I went to honda... they'll fix it for $250... they say its not a manufacturer's defect ...
Old May 24, 2004
So, magically, your car just started leaking, and it's not Honda's fault. Thats BS.
Old May 24, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Originally Posted by 909
2002 Si coupe.
WTF?
PLease Help.
You've mentioned removing door mouldings... Maybe you didn't reattached them correctly.
Has this happened before you removed your carpets? When does it occur? After the rain is over? Make sure this is NOT A/C related problem.
Without inspecting your car, it's impossible to determine your problem.
Old May 24, 2004
vietfob714's Avatar
thats a good idea with the manual car wash... thx alienmeatsack
Old May 24, 2004
909's Avatar
909
Thx for the reply happy,
"Maybe you didn't reattached them correctly..."
-----Pulled them off (white plugs) - snapped them back in. As long as they snap in the holes, not much more I can do to install them? -----
----- Yes , only removed the entire floor carpet to get rid of the stagnat water,...... washed and dried to make it smell like fresh laundry.----
"When does it occur? After the rain is over? "
----Exactly-----
"Make sure this is NOT A/C related problem."
---Where do I check bro?
What do I check for?----
"Without inspecting your car, it's impossible to determine your problem."
Come over and inspect it, when we find the source, there'll be a 24 of beer waiting for you
Old May 25, 2004
ren808's Avatar
ren808 is on a distinguished road
If water is coming in to the trunk its probably the rear bumper molding. Thats what is happening to my car. water gets in through the molding and runs underneath the rear seats. pop off the bumper and put it back on. if that doesnt work put silicone were the brackets attact to the car on the inside of the trunk.
Old May 29, 2004
lustywenchcapn's Avatar
lustywenchcapn is an unknown quantity at this point
I have been searching for the source of that water since I bought my car in 2001. I haven't made any mods whatsoever and yet I often have a wet mess on my floor that I'm sure can't be good.
Old Jul 9, 2004
vietfob714's Avatar
FINALLY FIGURED IT OUT! I took out all the carpet and everything. There is a little circular welding under where the brake is. Water leaks in through there if the welding isnt good enough. Stuck a little bondo on there and I'm leak free!
Old Jul 9, 2004
909's Avatar
909
vietfob714
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
NROD315
Sep 12, 2015 02:46 PM
wingsfan19
15
Sep 2, 2015 02:15 AM
mrwhos
Aug 11, 2015 02:03 AM
