ac wont turn on?
Old Mar 30, 2004
vandejr93's Avatar
vandejr93 is an unknown quantity at this point
Unhappy ac wont turn on?
my ac wont turn on anymore? i ran out of warranty at the dealer and they wont even look at my car because the say i have to many modifications? can anyone tell me whats wrong with my car? and hurry cause summers coming. the lights in the interior wont turn on. no ac no heater nothing. the controls dont work. how does the belt play a role, cause im not so good with ac and their functions. i checked any and all the fuses and their all good. please help?
Old Mar 30, 2004
PunkingCivic's Avatar
I need TP for my bunghole
check the belt
here is the whole ac system
Old Mar 30, 2004
Hey there,
You should add the info below that you PM'ed me to the problem on the site. I check the fuses if nothing lights up.
Check those and see there are some under the driver dash near the center console and eom in the engine bay.
"vandejr93 wrote on <font color="blue">Today</font> 06:16 AM:the lights in the interior wont turn on. no ac no heater nothing. the controls dont work. how does the belt play a role, cause im not so good with ac and their functions."
Old Mar 30, 2004
check the fuses here in the cabin
and here in the engine bay
All should be labeled.
Old Mar 30, 2004
here is a link to the first pic.
http://www.hondaautomotiveparts.com/...IT+%28CABIN%29
I think that fuses should be labeled in the control panel. you'll need to unscrew a bolt to decend the control panel fom under the dash.
Old Apr 2, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
^^^^^^agre'd....anytime you run into electrical problems, always starts w/ fuses. if you find yourself constantly changing the same fuse, you got problems. maybe an exposed wire or bad relay or something else. hope this helps
Old Apr 2, 2004
XtremeJM's Avatar
how is your freon? sp* I had a leak in my condensor and lost all my freon and when there is no freon the AC pump will not turn on.
Pir8pete
165
Mar 6, 2009 05:16 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
CapYoda
Jan 7, 2002 03:20 PM
blackbullet
Dec 1, 2001 03:44 PM
