normal coolant loss?
Old Mar 7, 2004
malice29r's Avatar
malice29r is an unknown quantity at this point
Does anyone else have to add coolant to their civic every once in a while?
I just checked a few things under the hood and noticed that my coolant resevoir is within about an inch of the min line.. i last topped it up to max a little over a year ago, which was about a month after I bought it..
As a car newb, I was under the impression that the cooling system was all sealed, and therefore nothing should evaporate, which leaves only it either being burned or leaking, and it's not leaking, i park in the same place every day on a smooth/fairly clean garage floor and i've never seen any abnormal fluids under there..
but then again that's such a small amount of fluid to disappear over a year I was just thinkin it might be normal?
thanks for any help
Old Mar 7, 2004
That's strange. I don't know because the dealer always fills fluids when I go for an oil change.
Old Mar 7, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
you are right, u shouldn't be topping off. 1st things that comes to mind is your head gasket, you go and have the cooling system check. they put some dye in and that will show leaks.
Old Mar 14, 2004
etdigitalis's Avatar
etdigitalis should not be trusted
I have had the same problem with my car since I first got it in Sep '01. About once a year I have to fill up the reservoir from slightly above the min to the max cold line. I've kept an eye out for leaks, but haven't seen any signs yet. My only guess is that it's either getting "burned" off or evaporating out of the reservoir... after all, that thing isn't air tight.
etdigitalis
Old Mar 16, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
all cars will evaporate some coolant over time if they do not use a completely sealed system. the overflow bottle is open to the atmosphere, and all fluids will evaporate at some point. ex. a gm system with the radiator cap ontop of the bottle is a completely sealed system.
Old Mar 16, 2004
if you find yourself constantly topping off ANY fluid, there is something wrong. like i said b4, dont be surprised if your head gasket is roasted. when driving, do you notice a sweet smell or excessice white smoke?????
Old Jun 25, 2007
stock's Avatar
stock is on a distinguished road
Re: normal coolant loss?
I think slowly evaporates from the overflow resovoir. If you notice, the overflow resovoir cap is not tightly sealed.
Old Jun 25, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
u needa get ur hoses check and radiator. worse comes 2 worse u have a crack in ur headgasket... garuntee it
Old Jun 25, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
A little bit over a long time is normal. the cooling system holds a little over a gallon. If you had to add 2" back to the overflow, you might have poured in 4-8 ounces of coolant. I wouldnt be worried.
Old Jul 2, 2007
CincyBlck2k1's Avatar
CincyBlck2k1 is an unknown quantity at this point
yeah, I agree with Boilermaker... i'd just keep an eye on it.. once a year isn't bad.. I just had to replace my headgasket.. but mine was the opposite... air was getting into the coolant and I had to keep bleeding out the system before I replaced it... the coolant kept rising up my reservior... and i think that's the symptom a lot of people have with headgaskets is air getting into the coolant and causing the level to rise... so, i'd just check it periodically.. top it off as needed and make sure to remember to get the pre-mixed coolant or to mix it manually before adding..
Old Jul 7, 2007
Medic_06's Avatar
Medic_06 is on a distinguished road
I have this same kind of problem. have topped it up once 2 years ago, and probably gonna have to do it again soon..I'm not to worried about it though.
oh well.
alxz310
Jul 30, 2015 12:18 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
1khilari
Jul 9, 2015 08:12 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
