whats broken?
Old Feb 20, 2004
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
whats broken?
on occasion my car will rev up and down to 4 grand from idle and stall after that, completely on its own. i assume its a problem with some kind of sensor....what could it be? also, its almost always when the engine is not warmed up.
Old Feb 20, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
check ur 02 sensor
Old Feb 20, 2004
o2 sensor not there, replaced by one of those resistors
Old Feb 20, 2004
I've had mine rev up to about 2500 rpms on cold days, but only when you first start it. It's most likely a computer or sensor problem, maybe caused by that CHIP you have. Those are nothing but trouble. If you're gonna get some kind of electronic upgrade, VAFCII by apexi is made for that.
Old Feb 20, 2004
no the chip is no longer there, the only thing that could be considered a tchip is that resistor, but this is not at startup, but usually a few minutes after
Old Feb 20, 2004
i did that throttle body heater bypass, do you think the throttle body could be stuck closed due to lack of lubrication?
Old Feb 20, 2004
Oh okay. No more messing with your car. Take that stupid resistor you got off ebay and throw it away. Does nothing. Neither does the throttle body heater bypass. Put it back the way it was, because that's your problem. The whole reason Honda installed that was to prevent the throttle body from sticking in COLD weather. Don't do stupid mods like that! Just trying to help. Take it from someone who's been down that path and realized it a year later.
Old Feb 20, 2004
resistor did 6 more hp to the wheels.
Old Feb 20, 2004
did your throttle body start sticking? mine has been bypassed since i got the car in 02'
Old Feb 20, 2004
Like I said before, I'm just trying to help.Put the throttle body heater back the way it was and problem solved. The olny people who disable it live in Florida, and even then there's no gain. I can't make you change your view on this stuff, but most cheap parts give little or no power gains. My old AEM intake actually gave me LESS power in lower rpms. But hey, it's your car so do what you want to it.
Oh and welcome to the site
Old Feb 20, 2004
haha yeah i dont use the site much. i also experienced loss of power on low rpm with aem. and yeah, i know those little mods dont do much, theyre just a product of boredom. thanks for your help.
Old Feb 25, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Depends on what AEM intake youre getting...
Also, why are you revving your car up to 4000 when it's cold??
Crazygrlinak
Oct 8, 2015 05:06 PM
Dave Brabant
Sep 9, 2015 08:11 PM
amrhamed
Sep 1, 2015 06:27 PM
mishima
Aug 22, 2015 06:32 PM
