CEL Problem Solved!
Old Feb 10, 2004
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Lightbulb CEL Problem Solved!
This is for those peepz who have a header and straight pipe (high flow cat) and wonder why the CEL comes on...well after having my Top Speed Stainless Steel Header and High Flow Cat on for about 5 months now, i can finally say that my CEL has FINALLY GONE away for good!!
I checked both my O2 sensors in the car - the one goin to the intake and the one under the car attatched to the high flow cat. Checked them out and everything was ok...note that prior to this my CEL had been on for a couple months...
I drive to Modesto and gas up at the Exxon station...(cheap gas)....and the light is still on.....and after partying during the weekend I gas up at Chevron (89 octane/white)...and on my way home back to Sac, my CEL goes off....the light just turns off....
So i'm like alrite, it does that once in a while, goes on and then off....but this time it stayed off...and it has stayed off for 2 months now....i'm wondering what it could be, but my theory is that it has to do with certain octane gas...i remember reading about it here on the forums...but I'm guessin that if you run ur car with premium gas like Chevron and make sure ur 02 sensors are koo and make sure ur gas cap is tight...it should make ur CEL dissapear for good...
Its either the gas or the ECU took half a year tryin to adjust to the pipes...hahaha...anyways that is my theory and sorry i took so long explainin it...just thought i'd tell u in detail...
Old Mar 13, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
89 octane is required you know for a header/high flow cat set-up. Don't go on cheap quality gas or it will make your car run like ****.
Old Mar 23, 2004
acidbaby's Avatar
The Beez Kneez
ive always run 93 octane and mine is on, and has been on for 5months
Old Mar 25, 2004
sw388integra's Avatar
i run 93 too, same problem until i got and o2 simulator from WannaBFast....then it cut off and got better gas mileage...
Old Mar 29, 2004
024drlx's Avatar
024drlx is an unknown quantity at this point
do both of you have the same header though.
Old Apr 19, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
so pretty much you need an o2 simulator for the CEL to not be on?
Old Apr 19, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
got the one from bigjoshracing.com doesnt work... emailed him to get some help... nothing heres a link some1 gave me on one of my posts for a o2 elim that actually works i dont have enough money to try it yet but some ppl says it works. For the price, it better work!
http://www.casperselectronics.com/c...i?product=HONDA
Old Apr 19, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
IMO the ECU just needs to reboot... that's what i did to my ride...
Old Apr 19, 2004
Shlomo's Avatar
vietfob714, i tried that link but it didn't work...how much is that one by the way?
Old Apr 19, 2004
Shlomo's Avatar
also, for everyone that just resets there ECU when the CEL comes on. What happens if the light comes on for another reason besides the removal of the cat? how would you know? isn't that dangerous?
Old Apr 22, 2004
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
it means that you should take your car for a check up, there could be many reasons for the CEL coming on, aftermarket cat except for the one from Random technology, gas cap not on tight, and etc. it just basically states that there could be something wrong and you should go check.
Old Apr 22, 2004
in addition it's not dangerous, it's mainly a warning
juror
May 26, 2015 06:35 PM
vtecbrah
May 12, 2015 01:30 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
Fastfebur
Apr 26, 2015 11:57 PM
civiccowboy
Jan 20, 2002 06:05 AM
