wierd engine noise
Old Feb 2, 2004
dirk21's Avatar
dirk21 is an unknown quantity at this point
wierd engine noise
ok the other day i got my oil changed and right when i hit the street i took off and all of the sudden there was this loud noise(like a very loud exhaust) coming from my engine. so i drove around for a while and my engine would get real loud in low rpm's in first and second gear. all other gears were fine and in high rpm's it was fine. after i drove for a while it went away. now it's been like three days and it just started back again and it's not constant i will be sitting at a stop light and rev my engine to 2,000 rpms and the noise is there and while i drive it is still there but when i get to the next light it's gone, so it does it on and off. i'm just kind of worried because it just cause it barely started and it's sad cause my engine is about ten times louder than my exhaust. well i just want to get it figured out what it is, so if any of you have the same problem or might have an idea what it is please let me know.
Old Feb 7, 2004
tom0826's Avatar
tom0826 is an unknown quantity at this point
If indeed this sound is related to your oil change, I would suspect that oil got onto your accessory drive belts, and the sound you hear is the belt slipping against the pullies, and usually heard at lower RPMs. It should go away after some time. Give it a week or two.
Old Feb 7, 2004
dirk21's Avatar
yeah well i finally had time to lift my car and look underneath and i found that i had an exhaust leak so everything is fine now. thanks anyways.
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
