taking door panel off
Old Dec 19, 2003
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
i'm taking my door panel off to fix a dent that is on my passengar side door. i read the diy but am still having a few problems and have questions i gotta ask. I can't get the door hinge off, after i unscrewed it from everything, and i can't get anything else to move after i unscrewed the bolts on the arm rest that is attached to the door. i know this isn't very descripitive at all, but any help is appreciated
Old Dec 19, 2003
robbclark1's Avatar
Retired suspension supermod.
there are a few screws. One in the arm rest under that little plastic cover. and then two bigger ones after you take off the arm rest. There are some behind the door handle. The rest is just pull the fvck out of it. It will pop off eventually.
Old Dec 19, 2003
The door handle has a latch with plastic holder that has to be taken out. You can see it through the panel. It's easy to use your fingers, but a screwdriver may work.
Old Dec 20, 2003
JCiv03's Avatar
DIY Door panel removal! (not my Diy)
http://robnkester.com/gallery/view_a...album07&page=1
Old Dec 20, 2003
robbclark1's Avatar
if you follow that DIY you DO NOT have to do steps 1a and 1b.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
