Check Engine Light HELP!!!!
Old Jul 30, 2003
crabby760's Avatar
crabby760 is an unknown quantity at this point
my car has 39,689 miles on it and i have a aem cai and tanabe exhuast and a aem cam gear retarded 2 degrees had those mods for over 6 months now and today on my way to work my check engine light comes on can someone please give me any ideas as to why it came on and any things i can do to try and get it to go off? my car isnt under warranty anymore and really i dont see why there should be something wrong for the light to come on.... well anything would help thanks..
Old Jul 30, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Mine just came on as well. Try resetting your ecu.
1. Disconnect negative plug on battery(black) for a few minutes.
2. Reconnect negative plug.
3. start car let run for about 10-15 minutes(do not apply gas while car is idling.)
4. Done(light should go away, but may return later. If so you may need to check it out at the dealer. I believe the check engine like is warranted for 3years or 60,000km or 3years 37500miles
good luck
Old Jul 30, 2003
crabby760's Avatar
did your light go off after that? and how mnay miles do you have? any my car isnt under warranty at all anymore...
Old Jul 30, 2003
AllMotorSi's Avatar
My light went off, but the next day i drove it and it came back on. My car has 79,000km or 49375miles. Gonna go into honda tomorrow, they charge 1hour labour to check if your over the warranty. Will keep you updated.
Old Jul 30, 2003
crabby760's Avatar
ok yeah tahnks man let me know what they tell you.... pleease
Old Jul 30, 2003
FALKEN's Avatar
Civicforums Junkie
did you guys try checking your gas cap??
Old Jul 30, 2003
crabby760's Avatar
wat would be wrong witht he gas cap and why woudl that make a check engine light turn on?
Old Jul 30, 2003
Got Boost???'s Avatar
why don't you read the little message on the gaas cap
But to save you time I'll tell ya what it says.
Ya know how the gas cap clicks when you screw it on??
Well on the cap it says if it doesn't click 5 or more times then the check engine light will come on. (i think its 5 but it could be 3 but better safe than sorry) just to be safe i click it oh around 20 times
Old Jul 30, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Maybe you have a bad oxygen sensor.
Old Jul 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
that would do it ... the engine light usually comes on.. because of those o2 sensors under the car ... one behind the cat and one on the header.... thats why mine is on .. but i have no cat and an hp header so i know why mines on...
Old Jul 31, 2003
ak's Avatar
ak
Retired Mod
Time for some Bosch Premium o2 sensors! heh... I wonder if Bosch's make ANY difference at all anyway.
Old Jul 31, 2003
Mr.Modify's Avatar
i know mine came one when i had my alarm installed and my TV"S installed in my car!!! cause it was spliced into the gear shifting something!!!
Old Jul 31, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
Yeah my CEL came on out of the blue one day... took it to autozone and used their code reader.. turns out one of my 02 sensors were bad, so I replaced them both. Now my cars been running great, not to mention my gas mileage improved about 50 miles per tank!!!
Old Jul 31, 2003
ak's Avatar
ak
Retired Mod
Holy crap.... how much were your o2 sensors? what brand did you get?
Old Aug 1, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea for real... how much ?
Old Aug 1, 2003
IDQcivic's Avatar
I just got the same OEM ones... I think they were 37 a piece... I got them at www.hondaautomotiveparts.com
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
