Electrical Post information/questions/Issues about Electric parts here.
Power accessory socket
Old Jul 26, 2023
Meanie's Avatar
Meanie is an unknown quantity at this point
My center power supply socket(cigarette lighter for you old timers) stopped working in my 2014 Civic Coupe EX. Manual provides fuse location 27 for front and 12 for center console in the interior fuse panel. I assume they mean center console as the arm rest and front as the power ports under radio Regardless, each fuse is still good and I can't find any other reason why it's no longer working. No burn smell from wiring or no smoke when it went out. I had a cup shape power inverter plugged into it and used my laptop. The inverter has it's own fuse and that is also intact. I'm lost. Suggestions? Thank you
Old Jul 26, 2023
Colin42's Avatar
Re: Power accessory socket
Checked for power and ground in the socket?
Old Aug 22, 2023
David13's Avatar
David13 is an unknown quantity at this point
Yeah, I have the same problem. However, I have not checked the fuses. You may have clued me in to where the fuse is.
As to power and ground in the socket, that is the problem. No power on it.
However, the usb port in the center console box does work.
Other ideas?
Thanks
dc
Old Aug 23, 2023
Colin42's Avatar
Go to the fuse....
if the fuse is good the problem is between the fuse and the socket.
happybilmore
Dec 26, 2014 04:51 PM
fatboyflip
Nov 5, 2009 03:27 PM
02rdcivic
Mar 13, 2006 11:04 PM
shaman
Dec 11, 2005 08:46 PM
Imtheconvict
May 19, 2005 09:05 PM
