12V power supply
Old Mar 13, 2006
02rdcivic's Avatar
02rdcivic is an unknown quantity at this point
12V power supply
So i am an idiot with the electrical part of our cars. It seems as though my 12V power supply quit on me, guessing its a blown fuse. I looked at the fuse box, however, I did not find where the fuse was for the 12V any info is appreciated. Not sure if it matters but its an 02 ex coupe
Old Mar 13, 2006
noooorb's Avatar
noooorb is an unknown quantity at this point
From where/which part of the car is the 12V wire that you are referring to?
Old Mar 13, 2006
iLLesTCivic's Avatar
iLLesTCivic is an unknown quantity at this point
its called cigertte lighter i think
Old Mar 13, 2006
12v power supply? you mean the battery is dead?
Old Mar 13, 2006
MegaHurtz's Avatar
Yeah, what 12v power supply?
Old Mar 13, 2006
02rdcivic's Avatar
oo my bad...it is the cigarette lighter. Thought i threw that in there
Old Mar 13, 2006
MegaHurtz's Avatar
It's under your dash somewhere, or the device you had plugged into the ligher port might have a fuse on it, you might have to open it up or screw off the end to access it
Old Mar 13, 2006
CraigW's Avatar
#18 in the under dash box = 15 amps
Old Mar 13, 2006
02rdcivic's Avatar
Thanks for the info
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Dave1984
Jul 22, 2015 06:10 PM
sch2cm
Jul 21, 2015 09:58 PM
breanna_17
Jul 21, 2015 04:01 PM
