Electrical Post information/questions/Issues about Electric parts here.
Mirror indicator lights aint working [solved]
Old Nov 6, 2022
Tessa's Avatar
Tessa is an unknown quantity at this point
Hi
i have a honda civic type s 1.3 2009
I recently got some new black led mirror indicator lights to replace existing ones. After installing one I tested it and it didn't turn on. I tried the other side with the original and it also doesn't turn on. I checked the fuse and on the fuse diagram says number 15 exterior small lights, I think this is the correct one, but it seemed fine I also changed it anyway.
Can anyone think of a reason why both mirror indicator lights wouldn't work or any ideas how I can fix this.
Thanks
Tessa
Old Nov 6, 2022
re: Mirror indicator lights aint working [solved]
recheck work done
Old Nov 6, 2022
Tessa's Avatar
Originally Posted by sdaidoji
recheck work done
it wasn't working before I even replaced it. I replaced it and still not working, also it is just a plug that i insert into the connecting psrt that comes out of the wing mirror. So I am unsure how much to recheck as I pushed it in really tight aswell.
any other thoughts?
thanks
Old Nov 6, 2022
check if wires at hinge are not broken/damaged - you open and close the drivers' door all the time, it damages the wires overtime
Old Nov 9, 2022
Tessa's Avatar
Turns out you were right the first time, just had to push it in super hard.
Rob Beasant
Electrical
Dec 30, 2024 04:08 PM
civtorc
Regular Maintenance
May 2, 2022 06:53 PM
jakeconnor
General 8th & 9th Gen
Oct 19, 2021 09:36 AM
MizKJG
Jan 6, 2019 02:55 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
