Electrical Post information/questions/Issues about Electric parts here.
2013 Civic, DRL lights working, High Beams working, Low Beams not working
Old Oct 16, 2019
Rob Beasant's Avatar
Rob Beasant is an unknown quantity at this point
I have a 2013 Civic with the daytime running lights working and the high beam lights working but the low beans do not work. I have checked the fuses and replaced the H/L relay but the low beans still do not work. Could the problem be the headlight combination switch? Any other possibilities?
Thanks for any suggestions.
Old Oct 16, 2019
Re: 2013 Civic, DRL lights working, High Beams working, Low Beams not working
Just a quick check since you didn't state that you checked this. You've verified the low beam bulbs are good, yes?
Old Oct 16, 2019
I replaced one of the bulbs. I thought the daytime lights use the same bulb as the low beams.
Old Oct 16, 2019
DRL uses the high beam
Old Feb 8, 2024
Ekallmotor516's Avatar
Ekallmotor516 is an unknown quantity at this point
Having same issue, DRL and high beam good. No low beam. Replace fuses even and relay under hood and dash. Still no power at lowbeam. Let me know if you fixed it.
Old Dec 30, 2024
nebulanoodle's Avatar
nebulanoodle is an unknown quantity at this point
Hey there, this is one of the first links to come up in a Google search and I stumbled into this issue as well. Having experienced the feeling of being a very dumb person and learning that the low beam bulb is a separate bulb from the high beam bulb on our 2013 Honda Civic, I wanted to hopefully help future “us” who have the misfortune of a headlight going out. This fact of separate bulbs is made painfully obvious even in the free and usually supplied owners manual.
May your path be illuminated 💡
Chris1htx
General 8th & 9th Gen
Jan 4, 2019 01:44 PM
Icebrand
Dec 28, 2017 09:21 PM
Maksat
Oct 24, 2014 09:29 AM
MohsinBharucha
Jun 3, 2010 10:53 AM
wambo
Jan 29, 2007 05:59 AM
