Electrical Post information/questions/Issues about Electric parts here.
Question about light latch on Honda civic 2013
Old Sep 4, 2021
haemma333's Avatar
haemma333 is an unknown quantity at this point
Hello,
Any help would be greatly appreciated. I am trying to change the daylight running lights (it burned out) on my honda civic 2013. There is a metal latch connected to this red wire (above the black wire) and I cannot get the wire/light out in order to replace it. Does anyone know how to get the latch open so I can change the DRL? Thank you so much!
Old Sep 5, 2021
Colin42's Avatar
Re: Question about light latch on Honda civic 2013
There's a little tab that the wire is hooked under. Push the wire towards the front of the car and you should be able to unhook it
Old Sep 5, 2021
you want to change the bulb, not the DRL.
DRL is a system that turn your high beams on as soon as car is turned on and the lights will be at half power (so it will not blind other drivers, but make your car more visible during the day)
i use a small screwdriver to move the retaining wires away on my car
https://www.google.com/search?client...lbs+2013+civic
Old Sep 5, 2021
to clarify: push the retainer wire in (toward the bulb), then outward, and it should release. Repeat for the other side
Old Sep 6, 2021
haemma333's Avatar
No wonder when I searched DRL bulbs nothing came up. Thank you for teaching me!
emaxxx4
Jul 14, 2018 09:04 PM
jemdogs
Lighting
Mar 18, 2016 12:33 PM
trev0006
May 22, 2013 12:33 PM
316
Oct 14, 2008 03:55 AM
Dizzymofo
Apr 24, 2002 06:10 PM
