Wiring questions for Backup Camera
Old Jul 11, 2018
emaxxx4's Avatar
emaxxx4 is an unknown quantity at this point
Hello. I received a backup camera system for my Civic for Christmas. I'd like to get around to installing it, but my primary concern is the ease of wiring to the reverse lights. I checked my Haynes manual and discovered the correct light socket; a three-wire connector of red, black, and green, and I know the black and red wires from the camera go to the corresponding wires of the reverse light.
Reverse light socket, only putting this here in case I read the Haynes manual wrong.
My question is regarding the best route to attach it. Should I cut off the connector, purchase a new connector and wrap the camera's red wire with the backup light's red wire (and same for black), or is it easier to use these old taps I've been holding on to instead?
Taps that I've held on to. One end has both channels open, the other end has one channel open for the existing wire.
There's a Honda dealership near me and I thought perhaps they had the connector in stock, but I'm also unsure as to if it would be able to take both red wires and black wires from the camera and light and have the connector snap tight securely. I'd just hate to get stuck and have to end up buying a whole new harness because of a dumb mistake (in case there's not enough wire for me to put on a barell connector and re-extend it.
Thank you for your help!
Old Jul 11, 2018
GolNat's Avatar
Prelude Owner
Re: Wiring questions for Backup Camera
I don't like those style clips.
I would cut, splice, solder and cover with heat shrink. Western union splice!
Old Jul 11, 2018
Vampire clips, because they SUCK
I soldered mine LOL
Regardless of wire colors, I'd first confirm power/ground on the suspect wires ---at the correct times--- using a voltmeter or test light BEFORE making any splices or connections
Old Jul 14, 2018
emaxxx4's Avatar
Thank you. Ultimately I had used butt terminals. I sliced the backup light socket in half and attached butt terminals on the ends, no solder (yet). I did attempt to pull them apart but they stayed intact. I ran a few pairs of about the same gauge wire to them, the camera's wires going in the same direction as the reverse light, tested it, and it works! Now all I have to do is run it under the carpet. I'm not sure if I want to cut a small piece of carpet and run the wire through there or drill a small hole with a grommet through the console instead.
Old Jul 14, 2018
That should be a decent crimp.
I ran mine around the fold down back seat, under the bottom cushion and pulled up the door sill trims to tuck along the carpet, up to the driver kick panel, then up into the dash.
bymitten
Jun 24, 2017 11:47 PM
fullgrown
Jul 28, 2005 01:59 PM
Xenin
Lighting
22
Jun 8, 2005 12:00 AM
toadstump
Dec 15, 2002 09:28 AM
Dizzymofo
Apr 24, 2002 06:10 PM
