Electrical Post information/questions/Issues about Electric parts here.
Critters chewed my harness
Old Aug 5, 2021
2007Si's Avatar
2007Si is an unknown quantity at this point
Stock 07 Si sedan. Critters chewed my harness that comes out at the end of the injectors. It feeds the oil pressure switch, vtec solenoid ( one that goes into the front of cylinder head) and crank sensor. All wires match up to the respective plugs except one. It's yellow with a red tracer. When ground is applied to this wire the low oil pressure idiot light comes on. Which wire does it piggyback to or does it go somewhere else? Wanna get it back running. Been down for 2 weeks now and can't find or trust just general Google pics. TIA.
Old Aug 5, 2021
BrotatoChip's Avatar
Super Moderator
Re: Critters chewed my harness
That should go to the oil pressure switch located around that same area. Block is upside down in the pic. This is the backside of the block on the passenger side.
Old Aug 5, 2021
ow, another wire chewed by rodents...
good lucky, it's common.
Old Aug 5, 2021
2007Si's Avatar
I understand what it does, just need to know which wire it piggyback off of. There are 2 wires going to the switch. Which one does it share with?
Old Aug 5, 2021
Super Moderator
Can you post some pics? I don't understand what you mean.
That pressure switch should have one wire going to it. The sensor itself is grounded through the block. When oil pressure is low the switch closes applying that ground to your yellow/red wire. Are you saying you have the wire on the sensor side but don't know where it goes on the harness side?
Kyle Hufford
Electronics
Dec 15, 2019 08:23 AM
upnorthguy
Jan 17, 2019 01:54 PM
glamabilly
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Sep 6, 2014 09:18 PM
Thaik
Apr 12, 2012 05:48 PM
twizzx
Aug 15, 2003 10:51 PM
