Electrical Post information/questions/Issues about Electric parts here.
Drl module location
Old Sep 6, 2020
FaustoC's Avatar
FaustoC is an unknown quantity at this point
Drl module location
Can anyone tell me where the Drl module is located on a 2010 civic sport?
Old Sep 7, 2020
Re: Drl module location
The micu. Its built into the fusebox under the dash.
And if replaced, it has to be programmed before the engine will run.
Old Sep 8, 2020
FaustoC's Avatar
I just need to resolder some of the connections. I just wanted to know where I could find the dry module and remove the circuit board to do the repair.
This was confirmed by honda but they would not tell me where the module was located.
Old Sep 8, 2020
Do both high beam headlights work?
Old Sep 9, 2020
FaustoC's Avatar
yes, both high beams work.
There is a fix on how to resolder the connections of the DRL circuit board on the internet.
I spoke to a mechanic and he said that usually fixes the problem.
I just needed to know exactly where the DRL module was located.
Old Sep 11, 2020
06 and newer do not have a separate DRL module.
But.
If you are able to fix yours, you should take pictures during your work and post a tutorial here.
WhoIsFluffy
Electronics
Apr 23, 2022 03:49 PM
jta
Lighting
17
Jul 31, 2005 11:41 AM
attil
Apr 13, 2005 10:36 PM
XxJDMCivicxX
Aug 19, 2002 02:34 PM
