Angel Eyes hookup questions and DRL not working.
Old Jul 21, 2005
jta's Avatar
jta
jta is an unknown quantity at this point
I think I F'd up my day running lights (DRL).
I wanted to hookup my halo light so I figure I hookup the black w/ blk and red w/ red that was going into the DRL bulb.
So basically I crimped up the ends together meaning that DRL and Halo red and black for the driver side and tested the outcome, well the Halo worked but my DRL did not come on for both sides, however my highbeem worked for both sides.
So I took the Halo red and blk wires out and only put back the DRL and still they dont turn on.
Also my DRL and Highbeem indicators on the gauge display are on if the night lights are not on.
Please some one help me, with how to hookup my halo and fix my DRL.
Civic 02, Sedan LX
Headlights are Generation 3, with H1 bulbs.
Thanks for reading.
Old Jul 22, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
i did not know civic had DRL. i don't know if the angel eye projector lights support that. good luck
Old Jul 22, 2005
streetglower's Avatar
if you live in canada, cars have DRL. I dont know much about it, but I am assuming that the DRL have a fuse or relay that control it, check that first.
Old Jul 22, 2005
jta's Avatar
jta
What am checking for on the relay, can you be more specific.
Like what colour is the fuse for DRL and how should reset it?
Old Jul 22, 2005
well first check the fuse. Pull it out and see if the metal contact has split in the middle indicating a blown fuse, if its blown replace it with a new one of the same rating. If it blows again, then you have a short in DRL circuit. Also without even pulling it out, if you have a volt meter, check to see if you power on both sides of the fuse. should have 12-13 volts on each side. if not, the fuse is blown.
Now if that is ok, go check the relay. I think it is a 4 pin relay like this
2 3
1 4
these are the contacts on the relay. If you apply 12 volts to pin 3 and 4, you should have continuity between 1 and 2. There should be no continuity between 1 and 2 with no power at 3 and 4. you should here a clicking when you apply voltage, if it doesnt, the relay is bad.
Old Jul 23, 2005
sorry I mixed up on the relay, so here is the actual testing procedures listed on the previous reply.
Old Jul 24, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
do you really need DRL's? I been running a year w/o DRL's and no Toronto Cop has harrased me, in fact most cops dont have DRL's
Old Jul 24, 2005
SavoroaX's Avatar
SavoroaX is on a distinguished road
I want DRL for my Civic, i have friend that has them on his 96 civic and its tight as hell
Old Jul 28, 2005
jta's Avatar
jta
2 3
1 4
It was the bulb that had a broken filament.
So I have now crimped the power and ground of both DRL/Highbeam and Halo together but I get DRL working and highbeam working but no Halo for both headlights.
What gives?
Old Jul 28, 2005
SavoroaX's Avatar
where can i get canadian headlights for my civic
Old Jul 28, 2005
jta's Avatar
jta
You want OEM?
Old Jul 28, 2005
01redJDM's Avatar
01redJDM is on a distinguished road
that means u fvcked up somewhere in wiring them, double check to see if u've connected the right wires. I've installed projectors couple of times but never had that problem. good luck
Old Jul 28, 2005
SavoroaX's Avatar
You want OEM?
i want Daytime running lights for my headlights and USDM doesn't have DRL
Old Jul 29, 2005
jta's Avatar
jta
I meant you want OEM from Canada they have DRL.
Old Jul 30, 2005
SavoroaX's Avatar
yes i want oem from canada
Old Jul 30, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Jul 30, 2005
dirtySAMURAI's Avatar
I log in from time to time
it's not a simple headlight swap. you're going to need the wiring harness from the canadian car, too, and that will probably cost more $ than it's worth.
as for the DRL and the angel eyes, do this: hook up your angel eyes to your parking lights. the DRL probably draws a lower amperage, so when you upset that, the fuse or the bulb will pop.
Old Jul 31, 2005
jta's Avatar
jta
Could you tell me what colour is the parking light wire and the ground, also how can I integrate the Halo wires into the socket of parking lights.
Thanks for helping.
alxz310
Jul 30, 2015 12:18 PM
viperGTS
Jul 27, 2015 08:40 PM
DerbyDad03
Jul 27, 2015 11:34 AM
cyc
Jul 22, 2015 01:14 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
