Electrical Post information/questions/Issues about Electric parts here.
Resetting a number of dash panel alerts
Old Dec 8, 2015
Daleford's Avatar
Daleford is an unknown quantity at this point
I am repairing a 2015 Civic that never made it off the lot. Late one Sat night/early Sunday morning, a one-drink-too-many driver left the highway and drove over the engine hood of this car. Sheet metal damage only but I am getting 7 messages on the dash screen. They are:
Check brake system
Check ABS system
Check VSA system
Check Hill Start assist
Check DRL system
Check power steering system
Check DRL system [repeated]
Just about all of the above systems are working fine so I am thinking all the warnings are simply from the car being all "shook up".
Question: Can I reset any or all of these warnings or do I need to take it to the dealer?
Old Dec 8, 2015
Re: Resetting a number of dash panel alerts
Do you have a scanner that can access all of the above systems?
The dealer does.
DRL uses the high beam headlights, make sure the high beam lights light up when the car is running (highs on dim) and low beam headlights on (highs off), and high beams on (highs bright)
Brake/ABS/VSA/hill start are all related to the ABS system. EPS issue may or may not be related to the ABS faults but they all share data and electronic info for VSA operation. One single fault could turn on all those lights.
Old Dec 9, 2015
Daleford's Avatar
OK, so it needs to be scanned. THANKS for the info.
[I have a Corvette that I can scan and reset from the drivers seat so was wondering if this was the same]
Old Apr 28, 2021
eladioperez's Avatar
eladioperez is an unknown quantity at this point
I had a little accident where the right bar was damaged (wheel rim broken also). I have 4 of those: "Check VSA System, Check Hill Start assist, Check power steering system" and Check TPMS system"
Old Apr 28, 2021
I also bought a scanner. There were no system errors in the log. The car runs perfectly. I have to keep clearing those messages every time I start the car.
Old Apr 29, 2021
if they come back, there is actual issues that need to be addressed before you reset them again.
1- have someone check if battery and charging (alternator) good. Low voltage/current causes havoc in electronics.
2- after and accident? sensors can get knocked out of place, they will need to be checked.
Old Apr 29, 2021
one of the common causes is wires chewed by rodents, mind you.
so, check wiring, sensor, etc
no easy answer
Yanks12025
Aug 16, 2017 06:27 PM
Jay Lock
Aug 4, 2016 12:23 PM
JDMVTECB20
South Cali
26
Aug 31, 2004 10:56 PM
skaterboy
Jul 20, 2003 12:30 PM
fonto
Feb 5, 2003 12:49 PM
