Brakes Post information/questions/Issues about Brakes here.
Front brake pad replacement and bleeding
Old Feb 18, 2020
sjensen's Avatar
sjensen is an unknown quantity at this point
Hi,
I have found many resources online showing instructions for replacing the front brake pads and many of them does not use the bleeder valve when pushing back the caliper piston but instead let the brake fluid be pushed back into the system and back into the master cylinder. Even the Chilton repair guide does this. However, others _strongly_ recommend not doing that because you might potentially push dirty fluid into sensitive components such as ABS system. Instead, they recommend to open the bleeder valve and have the excess fluid come out there.
What is the recommended way then?
Thanks!
Old Feb 18, 2020
GolNat's Avatar
Prelude Owner
Re: Front brake pad replacement and bleeding
I always just push the cylinder back in and let the fluid go back the reservoir. If your brake system has been properly maintained then the fluid should be ok. If not then I might bleed it first.
Old Feb 19, 2020
Colin42's Avatar
I used to just push the piston in, now I crack the bleeder and then push the piston back. As long as your fluid isn't really nasty it won't hurt anything. Also if the bleeders are super rusty you may cause more problems trying to crack them open.
RDS
May 29, 2014 11:53 AM
scottroll
Jun 27, 2012 09:50 PM
mnea
Oct 19, 2010 02:58 PM
newbie101
Wheels and Tires
Jan 23, 2010 11:34 PM
civicdude
Brakes
Nov 21, 2001 08:00 PM
