Power Steering Fluid in Brake System
Old May 27, 2014
RDS's Avatar
RDS
RDS is an unknown quantity at this point
So I put power steering fluid in the brake system and drove about 75 miles before realizing what I'd done.
My question is, what can I do to rectify this, can I bleed the system and leave it at that? If not, what parts will need to be replaced?
My car has ABS, and the light hasn't come on yet, the brakes seem to work fine, I put about 4 ounces of power steering fluid in the brake reservoir.
Old May 27, 2014
Poopies's Avatar
Super Moderator
Re: Power Steering Fluid in Brake System
Bleed the bejeezus out of all 4 wheels, but make sure you keep replenishing the reservoir with new fluid. Then bleed it some more. Make sure the brake fluid starts coming out the same color as the stuff you're putting in. Make sure there are no air pockets in your lines. Chalk it up to experience, drive safely!
Old May 28, 2014
mikey1's Avatar
where is a picture of Homer Simpson saying D'OH! when i need it?
but seriously.....
most of the fluid you added will most likely still be in the brake master cylinder, no point in pushing all that fluid through the entire system,
i would suck the master cylinder dry first....then top it up with brake fluid and bleed the system,
Old May 28, 2014
How far do you think the oil got?
Do you know what petroleum does to rubber brake seals, and how quickly that damage is done?
I'd say to replace the master cylinder just to avoid the inevitable problem of swollen master seals and brakes that apply themselves...... and I'd want to clean out (backwards) the brake lines as far as possible before the new master goes on.
Old May 29, 2014
RDS's Avatar
RDS
Thanks everyone, I siphoned what I could from the reservoir, added brake fluid, drove it around a bit, siphoned it again, the brakes still work, they feel mushy, but IDK if that's just my imagination.
I'm just gonna replace the master cylinder, calipers, drum cylinders and end lines.
I'm hoping I can source all parts for less than $200.
Old May 29, 2014
RDS's Avatar
RDS
I have one question, the parts mentioned above, if my car has ABS, do they need to be for an ABS car or is it the same between ABS and non ABS? Would I need a new ABS pump?
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
anddrrey
May 11, 2015 02:30 PM
bsmiley
Apr 27, 2015 01:27 PM
