01 civic brake ? need help asap
Old Jun 5, 2014
skinner1790's Avatar
skinner1790 is an unknown quantity at this point
ok 01 civic did front brake job rotors plus pads driver side rotor rubbing sound under 20 no sound over 20 rubbing noise (warped rotors be fore) so i changed them i drilled out screws they were stripped i bled the whole system new fluid but i still have the grinding (squeal) brakes don't pull i put my hand by front tire if they were sticking would be warm no different then passenger side back side of rotor worn. i am confused i pulled off other side no rotor wear yet what am i missing and yes i did grease slide pins would it be a bent shield from when they were warped? i need some in sight it only on driver side pass side does not do it? PLEASE HELP!!!! i dont want to ruin new rotor it just annoying i think it is either rotor or bad caliper but the pin pushed in fine when i put back in to put new pads on. no sticking or nothing.
Old Jun 5, 2014
evansdad331's Avatar
evansdad331 is an unknown quantity at this point
Re: 01 civic brake ? need help asap
sounds like a sticky caliber. the piston isnt backing off the rotor as it should.
Old Jun 5, 2014
Ok so I gotta buy a new caliper it bakes fine don't seem like sticking though or what other options do I have
bsmiley
Apr 27, 2015 01:27 PM
