Vibration at 55-60mph under load
Old May 28, 2023
Wavey63's Avatar
Wavey63
Wavey63 is an unknown quantity at this point
Any help with this issue would be great. My 2012 civic ex vibrates in the front at around 55-60 mph when you are accelerating and the more they load, the worse it gets. I checked the CV boots and they appear fine with no tears. Is there any things I can check to see where the issue is? Thanks in advance!!!
Old May 29, 2023
Colin42's Avatar
Re: Vibration at 55-60mph under load
Checked tires? Suspension? Brakes?
Old May 29, 2023
Wavey63's Avatar
Wavey63
Tires are in good condition and balanced. In fact it has done this since before current tires. Brakes I wouldn’t think would have anything to do with this since it’s only under acceleration at said speed. Is there anything specifically in suspension I should check first? I have seen this issues discussed on the net and some people say transmission, some say bent drive axle, etc.
Old May 29, 2023
motor mounts? Transmission mounts?
Old May 29, 2023
tie rod ends? ball joints? control arm bushings?
Old May 29, 2023
Wavey63's Avatar
Wavey63
Tranny and motor mounts seem fine visually. Is there any one item that is most likely to cause this? Thanks for the help!
Old May 29, 2023
so many, only lifting, prodding will give you an answer
crow bar and start pushing things around
Old May 29, 2023
Wavey63's Avatar
Wavey63
Thanks again. I will respond if I come up with any more info.
Old May 30, 2023
BrotatoChip's Avatar
Super Moderator
You could try swapping tires front to rear to see if the vibrating stops.
Old May 30, 2023
When's the last time you got an alignment?
theprez1980
General
Oct 13, 2020 07:28 AM
JRC
Exterior
Apr 25, 2020 01:11 PM
jtrothrock
Electronics
Feb 21, 2019 10:45 PM
bucwylde23
Oct 13, 2017 03:14 PM
BarryB
May 13, 2013 07:41 AM
