Rack and Pinion - Steering Column Bolt
Old May 19, 2023
ripken2d12's Avatar
ripken2d12 is an unknown quantity at this point
Hi this is my first post here and I'm trying to replace my rack and pinion. Unfortunately I got to the first screw that I was supposed to remove inside the car that connects to the pinion assembly inside and stripped it. The bolt is on very tight and there isn't much space in the area so it's hard for me to work in there. Any advice on what I should do next?
I circled the bolt that I've stripped here.
Old May 20, 2023
Colin42's Avatar
Re: Rack and Pinion - Steering Column Bolt
For next time turn the wheel so there's more access to loosen the bolt. Then turn the wheel straight. You could try an extractor, or take it to a mechanic
Old May 20, 2023
ripken2d12's Avatar
Thanks will try the bolt extractor and hoping it will work!!
Natedawg
Feb 5, 2018 07:21 PM
chi_tea
Aug 17, 2016 01:52 PM
HempForPres
Feb 14, 2015 06:17 AM
VA_Civic
30
Feb 21, 2011 03:51 PM
P.O.S.B.A.S.04
Apr 17, 2006 08:41 PM
