Alignment done: worthy of new tires?
Old Oct 8, 2019
Thaik's Avatar
Thaik will become famous soon enoughThaik will become famous soon enough
Hi guys, it's been a while,
Some of you might remember some of my post about our family's 7th Gen Civic, now we've moved on to a 8th gen Civic, precisely a Honda Civic 2010 EX-L Sedan Manual (Canadian model) with Stock suspension.
The car was purchase back in July and I've went for an alignment because the car needed new tires. Obviously, I have tons of questions, but I'll start by sharing the alignment sheet before, what do you guys think based on your experience and expertise?
I don't feel confident in putting new tires with these specs, considering the camber readings especially the rear when my car does indeed have the 'C' marks on the rear upper control arm.
Without further redo, here's the alignment results along with the Honda Specs sheet directly from the Honda Shop Manual from Bishko.
Forgive the french, it has been done in Montreal!
PINCEMENT = TOE
CARROSSAGE = CAMBER
CHASSE = CASTER
POUSSEE = I don't know what that is though, means Push in french.
I appreciates whatever feedback you can provide, but I obviously have questions I need answered, I'll ask them afterwards following your feedback.
The most obvious one is: Has the job been done correctly, meaning, can I put new tires and not worry about uneven and prematured tread wear?
Thank you!
I apologize, I was unable to resize or simple attach the pictures with the post, I've only managed to insert them in line.
Alignment Before & After
Honda Civic 2006-2011 Alignment Specs
Old Oct 9, 2019
GolNat's Avatar
Prelude Owner
Re: Alignment done: worthy of new tires?
Camber won't wear the tires as much as bad toe and that camber reading is not that extreme.
How are the current tires wearing? If they wore okay then the new ones should.
Old Oct 10, 2019
but toe should not be that hard to correct...
take back?
Old Oct 10, 2019
Thaik's Avatar
Honestly the car has two sets of different tires, 2 Firestone Fuel Fighter up front, and 2 GoodYears, both All Season Tires. I just rotated them, but the GoodYear are shot, cracked, all worn out, almost no tread left.
I don't know how recently the tires were rotated the last time before we got the car, but I'll go ahead and check the front Firestones that used to be up front.
My question to you is, does this appear to be normal camber settings in the rear for a stock car that barely has 60K miles?
Old Oct 10, 2019
Thaik's Avatar
I'm honestly on the look out for a good alignment that knows what they're doing, I don't trust this one since they can't even get the toe right. Any advice how to find a good one? Should I look for alignment shops that knows Hondas?
Old Oct 10, 2019
Thaik's Avatar
Post Re: Alignment done: worthy of new tires?
Thanks for the feedback guys.
I'd like to have more inputs from you guys as I have many questions.
I know our cars the at least the Civic7th and 8th that I know, only has the toe adjustable in the front and in the rear.
Despite that, camber setting both up front and in the rear and the caster angle did indeed change a bit.
Can someone tell me if my camber up front and in the rear are way off, and if so, can I be corrected by adjusting the toe setting?
About the caster angle for the front passenger side, can I be corrected by an alignment, or is it caused by a bad suspension component ? The shop did tell me there was no play but I'm sure if they actually made sure or assumed it was.
I'm asking this all based on your experience with your alignments done in the best when the car had stock suspension with no camber bolts up front.
Old Oct 10, 2019
Thaik's Avatar
take back?
**Sorry for double posting, is it possible to delete a duplicate post**
Last edited by Thaik; Oct 10, 2019 at 05:15 PM. Reason: Apologies for double posting
bo_red
Apr 23, 2015 10:09 PM
ngm
Feb 23, 2014 12:08 PM
05reverb
Feb 9, 2007 01:37 PM
vietstylez
Sep 12, 2004 02:03 AM
Shadow_Saint
Sep 5, 2003 05:14 PM
