Help! I put wrong ATM fluid!
Old Oct 11, 2025
2012's Avatar
2012 is an unknown quantity at this point
Hi all,
I have a 2012 Civic LX AT, which should use ATF DW-1 fluid (pink), according to my search.
Somehow, I accidentally put 1 qt of HCF-2 (yellow) out of my mind. As soon as I put 1 qt, I realized the color was different.
Based on another search HCF-2 is for CVT, which can/will hurt my car. Now I want to completely drain 1qt of HCF-2 in the car.
I drained the new fluid after a few minutes, but another pink came out. I knew that through the drain plug I could not drain all.
So far I didn't start the engine. Hopefully the new fluid didn't get into the torque converter.
My questions are:
- Is there any way that I can drain or pump out the remaining HCF inside (DIY)?
- If not, how many complete drain/flushes should I do with new ATF-DW-1?
- During the drains/flushes, is it ok not to start the engine or drive the car?
- If I repeat the drain/flushes 3-4 times, will it be enough (the remaining HCF will not hurt my transmission)?
Any comments will be appreciated.
Old Oct 17, 2025
FRSam's Avatar
Click Here
Re: Help! I put wrong ATM fluid!
Three drain and fills. No flushes.
sjs8415
Transmission DIY
Jan 21, 2020 03:49 PM
Kennykenny
Jul 25, 2016 07:12 AM
CivicVoz
May 17, 2012 07:38 PM
combinatorix
15
Nov 5, 2011 12:05 AM
mikey1
Mar 29, 2011 07:45 PM
