So I changed my ATF...
Old Jan 6, 2020
sjs8415's Avatar
sjs8415 is an unknown quantity at this point
When I removed the drain bolt, fluid was very dark but only about a liter or less came out. That was first uh-oh moment.
So after draining, I put 2.5 L in the dipstick hole, run the engine for 15 sec and checked the dipstick. fluid level was nowhere near minimum level. Second uh-oh moment.
At that point, I figured the fluid was really low and not changed for long time and put 0.5L more and it overflowed. After cleaning mess, I ran the engine for another 15 sec and checked the fluid level to see the level being in middle.
I added 0.1L more just to be sure, and wrapped up.
I will drain and fill again soon, but even after the fluid change I can still feel the slip from 2nd to 3rd- and 1st gear shifting at 3K RPM now. It shifted 2.5K RPM with same level of acc. applied. Should I be worried?
Old Jan 6, 2020
Colin42's Avatar
Re: So I changed my ATF...
Do 3 drain and fills in a row with a 10 min drive in between each to get the fluid warm and engage all the gears. It's possible that the trans has permanent damage from being run with low fluid for a long period of time. Try the 3 drain and fills first, fluid is cheap.
Old Jan 6, 2020
Wankenstein's Avatar
Which ATF fluid did you use? After the 3x3 drain + fill Colin suggested you may want to try this as a last effort if there is still a shifting issue:
Amazon Amazon
Old Jan 6, 2020
sjs8415's Avatar
I was thinking doing once more next week, do you think I should expedite?
Originally Posted by HR Puffinblunts
Which ATF fluid did you use? After the 3x3 drain + fill Colin suggested you may want to try this as a last effort if there is still a shifting issue: https://www.amazon.com/Lubegard-6090.../dp/B0007ZAJRM
I’m using Valvoline Maxlife. Maybe I’ll add this on 3rd fill when there’s still slips.
Old Jan 6, 2020
Originally Posted by sjs8415
I was thinking doing once more next week, do you think I should expedite? I’m using Valvoline Maxlife. Maybe I’ll add this on 3rd fill when there’s still slips.
If it's not shifting properly after a 3x3 drain and fill then there's most likely internal damage. It wouldn't hurt to try the lubegard additive as a last resort but keep your expectations low.
Old Jan 7, 2020
Colin42's Avatar
The way I described is how to do it according to the factory repair manual, except they would run it on a lift.
Old Jan 7, 2020
sjs8415's Avatar
I'll try driving a bit more this week, maybe the ECU is confused from ATF back in normal level?
But how likely will my transmission fail, like being stuck in gear? A bit of slip is fine for me considering it's done 384K Km now.
Old Jan 7, 2020
Colin42's Avatar
thats wishful thinking....
Need to do the 3x drain and fill to see, you might get lucky
Old Jan 21, 2020
sjs8415's Avatar
Done 2nd drain and fill, slip is reduced. Might be better on 3rd...?
Old Jan 21, 2020
Colin42's Avatar
Certainly worth trying for the $30 in fluid
Kennykenny
Jul 25, 2016 07:12 AM
Chuck K
Mar 16, 2016 08:26 PM
CivicVoz
May 17, 2012 07:38 PM
combinatorix
15
Nov 5, 2011 12:05 AM
mikey1
Mar 29, 2011 07:45 PM
